Originally posted by Pentaxor with regards to shallow DOF, the 25/1.4 although it has good isolation, it is still not at efficient or as blurry in comparison with something on APS-C. the Nokton seems to be good though, but loses on AF functionality and some enhancements.
I used to think that way, but I really don't anymore. Obviously smaller sensors (including APS-C) can't match 35mm, but I've found both are sufficient for my needs. Take
this sample photo of a cat from the new Leica 25mm f/1.4 for example. The cat's nose is in focus and the ears are already soft. I simply don't need more DOF control than that. Furthermore, at 25mm's I wouldn't even use that lens as a neck-up portrait lens. I use a 50mm f/1.4 for that purpose. If Panasonic or Olympus make a 50mm/1.4 that is actually sharp wide open it will be over kill for me. At some point you just have to compose properly instead of using bokeh to blur out everything. I've seen tons of pics with the Canon 85mm f/1.2 where I've thought that would be a much better photo had they shot at f/2.8 instead of 1.2.
One area of concern is if you want shallow DOF in wide angles. I admit that is challenging, but
as this photo taken at 14mm @ f/2 shows, it can be achieved. Of course that photographer also used perfect composition along with a nice bokeh effect. Had he not composed that properly the photo would have been crap. I think that's where the difference lies, with full frame you can use blur to cover up mistakes or things that are sometimes out of your control (busy crowds for example), and with smaller sensors you have to work around them.
