02-19-2011, 10:18 AM   #16
ogl
ogl's Avatar
QuoteOriginally posted by séamuis Quote
yup. a 16 is a 16 is a 16, regardless of sensor size.
+1
02-19-2011, 10:30 AM   #17
What if Hoya/Pentax...
I know it's a little far fetched but what if Hoya/Pentax release a EVIL camera compatible with Samsung mount?
They have worked together before (Samsung GX cameras, Samsung sensor).
It could be good for both companies.
Have fun,
Luis
02-19-2011, 01:59 PM   #18
QuoteOriginally posted by lpfonseca Quote
Have fun,
Luis
An unbelievably fantastically brilliant idea. What a foresight. Hew!!
02-19-2011, 03:32 PM   #19
gazonk's Avatar
If, for instance, a 16 mm just barely covers the m4/3 image circle, it certainly doesn't make sense to call it an "ultra wide" - it can only be used as a moderate wide angle regardless of sensor size.
02-19-2011, 05:07 PM   #20
Talisker's Avatar
QuoteOriginally posted by ogl Quote
Your posts are full of delirium.
Try to learn lenses hardware.
16 mm lens is ULTRA-WIDE lens. Any lens has REAL focal length.
Indeed, but the word 'wide' refers to the the field of view, NOT the focal length, so WILL vary with the sensor size.
Even at FF cameras lenses with focal length from 8 till 24 mm are ULTRA-WIDE lenses.
You're going the wrong way and referring to larger sensors - stick a 16mm lens on a cameraphone and see how wide it is...
There is standart classification of lenses.
Show it to us then - there's no ISO standard for when you can call something an ultra-wide angle lens... Marketing departments call things whatever suits their needs, and they think they can get away with
02-20-2011, 12:28 AM   #21
ogl
ogl's Avatar
QuoteOriginally posted by Talisker Quote
If we say about 16/2.4 - I can say that optical designers develop lens with 16 mm focal length. Not 24 mm at APS-C.
There was and there is undercover standart from film era for focal range. Not any marketing and ISO. It's optics laws.
http://en.wikipedia.org/wiki/Focal_length
For example, Bojidar uses old good standart - Pentax K-Mount Lenses and Lens Accessories
02-20-2011, 01:03 AM - 1 Like   #22
This is absolutely wrong!
Sure, 16mm is 16mm, regardless of the sensor size.
But it may or may not be a wide angle lens depending on the sensor size!
For example, a 16mm lens on a 1/2.33" sensor would be a medium telephoto lens! (85mm equivalent)
That's something you yourself need to do.
02-20-2011, 01:18 AM   #23
The only lens that makes sense to me is the 16 mm pancake. The rest are going to be big lenses on a small camera. Not pocketable by any means, or even close. Why not just get an SLR if you are going to get an 85 mm f1.4, or a 700 mm lens for that matter?
You may want to have a small system for general use (travel, family outings etc), but then have the option of using faster lenses as well. That being said, I would much prefer using a pancake lens on the K-5 for compact use, and the option to attach a grip for bigger lenses. These mirrorless cameras will never be comfortable to use with something like a 70-200mm f/2.8.
02-20-2011, 01:25 AM   #24
ogl
ogl's Avatar
QuoteOriginally posted by nosnoop Quote
We say about interchangeable lens system and interchangeable lens system classification. Not about P&S
And we say about NX system now.
02-20-2011, 01:40 AM   #25
thibs's Avatar
Do you even understood the post you did reply to?
02-20-2011, 01:41 AM   #26
thibs's Avatar
Nosnoop, we're losing our time with Ogl.
02-20-2011, 03:44 AM   #27
JHD
You should try something wider than 16mm (like 10mm) and then get back to us!
02-20-2011, 03:49 AM   #28
RonHendriks1966's Avatar
Oh may, well I just googled it.
Ultra wide angle lens - Wikipedia, the free encyclopedia
An ultra wide-angle lens is a lens whose focal length is shorter than the short side of film or sensor.[citation needed]
Thus the term denotes a different range of lenses, relative to the size of the sensor in the camera in question.
For APS-C any lens shorter than 15 mm is considered ultra wide angle.
For 35 mm film or full-frame sensor any lens shorter than 24 mm
For 6x45 any lens shorter than 41 mm
For 6x6 and 6x7 any lens shorter than 56 mm
This makes sence, not that the lens is a different thing, but as in the name it is about the angle of the lens on the camera wich you take the picture with. So for 645D is 30mm to be considdered Ultra Wide Angle. This is as I see it correct somthing about 50 % of the diagonal of the sensor/film size.
And I found this: http://www.kenrockwell.com/tech/how-to-use-ultra-wide-lenses.htm
02-20-2011, 04:58 AM   #29
ogl
ogl's Avatar
QuoteOriginally posted by thibs Quote
No. English is not my language. Mr. Hamite
02-20-2011, 05:39 AM   #30
I have the NX10 +20 & 30mm pancake and all I can say is that, so far, I am puzzled by the quality of the glass Samsung is putting out.
These are small, well made, affordable AND of excellent optical quality.
If the 16mm is of the same wood, I'll buy it as soon as it is out.
I'll also buy the 85f1.4, even if it's bigger (whos say's that Samsung doesn't have a beefier, more upscale model coming to go with these lenses?). The NX10 will make for an excellent portrait camera with it's very precise and versatile AF.
700mm? For the life of me I can't even imagine the look of it with a NX attached!
They should just sell it with a NX as rear cap!
future, lenses, line, nx, ois, pentax news, pentax rumors, samsung, samsung nx, system
Samsung Ad shiner General Talk 3 03-20-2010 02:07 AM
Size of Samsung NX-10 compared to Pentax K20D, Samsung GX-20 Clone Samsungian Non-Pentax Cameras: Canon, Nikon, etc. 11 01-21-2010 12:26 PM
Samsung Techwin's camera biz is now Samsung Digital Imaging and its NX plans. samsung Pentax News and Rumors 3 03-13-2009 08:42 PM
Samsung RAW Converter (SilkyPix) confines to Samsung DNG only dancheng Digital Processing, Software, and Printing 0 04-27-2008 06:03 PM
All times are GMT -7. The time now is 02:59 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
