Originally posted by falconeye Appearently, a version 1.03 is imminent, promised to fix the AF low light issue. This is news from after this thread started. You'll find clues within it.
I cannot check right now. Are you sure you looked up the AF spec rather than the metering spec? I asl because I remember the metering spec contains a reference to the lens which is logical too.
Yes,
The K10D and K20D both say EV -1 to 18 ISO 100 f1.4. The K5 does not mention f1.4 in the AF spec, only ISO 100, but all call this a brightness range, which I would normally think of as LV, not EV. LV does not make sense as it does not tell you much about how much light hit the AF system.
All of the service references I could find specify the AF adjustment process in LV, not EV, but that is because they use a calibrated light source that has to be set to make the test.
Anyway, as we all have seen over the years, what I call PEnglish or Pentax English often makes many things less than crystal clear.
So, given the ISO and f stop used on the older camera specs, at EV 0, f1.4, ISO 100, the shutter speed had to be 4 seconds.
Don't get me wrong, I tested my K5s with the FA50 f1.4 and did not see a huge difference from other lenses, but I only own fixed aperture lenses and only one slower than f2.8.
Ray
