Originally posted by dlacouture BINGO!!!!
So, under a given light level threshold, the camera will revert to "daylight focus"...
Just done another dumb test: still using my "100% FF" test scene, I added a small tungsten light at the edge of the scene, but not as a focus point, and taking care that it would not light the AF target. So, theoretically, it should have no impact upon focusing, except by giving a good light temp reading to the colorimetric sensor...
Guess what : the camera focuses spot-on!!! It surely identifies the tungsten light and applies the proper focus shift...
dlacouture, you are my hero!
You did both tests I didn't find time to run and found results as predicted by the theory.
Moreover, you found that the colorimetric sensor falls back to daylight if it can't take a light temperature measure. So, the 250µm shift I see probably is the correction value between daylight and warm tungsten which is a hefty value.
Probably, the corresponding shift for the K-7 is smaller (if it exists) and maybe it is so because the AF aperture is smaller (less sensitive to light).
So, after all, we may see the downside to the increased light sensitivity of the new AF module. I've been told as a child that there are two sides to the same coin
Originally posted by Christine Tham Are we sure the K-7 does not have a problem?
Now that you ask: No, actually not. But maybe, it is less pronounced.
Originally posted by Christine Tham So my fear is that whilst Falk's theory explains a lot, it may not explain everything.
That's my fear too. Esp. I have some doubts how it would explain what is going on below the Planck scale (sorry, not everybody will get the joke ...
Originally posted by Christine Tham So it seems turning the AF fine adjustment on and off does impact the issue.
Ok, you just added another dimension to the problem
Anybody wanting to repeat Christine's test? If confirmed, we should leave AF adjustment alone.
Just to be sure:
Christine, you entered "0" for both, per lens AND global adjustment, when using "0", right?
