Originally posted by falconeye I said something about it in the paper itself.
What is appearant from the results is that we have two clusters of data which are clearly separate from one another.
Let's call them the good and bad cluster.
The scatter of data within each cluster may be tolerable.
This is what I meant by "the cause must be non-linear".
Even if it is hardware, then a proper detection of the fault situation could be used to improve things in software.
Non-linear hardware faults are frequent. But in many cases irreversible. Think of a broken leg
So, the steep jump from one cluster into the other (focus jump) makes a software issue more likely. Of course, it could be a digital chip which can't be updated. But even then, the firmware could know the condition when the digital chip fails and correct the input it receives from it.
I see an 80% chance that a firmware fix can be made. But only a 60% chance that Pentax takes it serious enough to allocate the good people to the issue. Which makes a fifty/fifty chance we'll ever see a fix. Which is inacceptable, IMHO.
Falk:
Thanks a bunch for your efforts and the
complicated paper (I have problems understanding it all
) provided in your blog.
I've downloaded the PDF file on my desktop for further reading ... that will take me days!
So the issue is real and there is a chance (80%) that a firmware fix could be made: are you implying that there is an 80% chance of a firmware update would
fix the problem?
I sure would be happy with that.
I'd like to think that since
focus jump seems to be the problem, that a firmware will be soon available even with the possibility that hardware (
digital chip) is at fault.
Pentax will likely take a serious
look at your paper but, as you said, whether they will provide a solution remains to be seen.
I am optimistic though and I believe that they will come up with some way of adressing the issue.
After all, it is all about Pentax not "losing face", isn't it?
JP
