04-23-2011, 09:24 AM   #16
thibs's Avatar
Mmm it says 16.2MP but still, sensor used in this?
Mirrorless Rumors | Home
04-23-2011, 03:54 PM   #17
falconeye's Avatar
QuoteOriginally posted by dosdan Quote
What could be happening is that, in a vert. column, only every 2nd pixel is read in a pass (for speed?), maybe alternating between passes, so that would mean that out of 5120 pixels in a column, 2160 effective pixels are read at a time.
4.2 μm * sin 45 * 5120 = 12.8 mm height
Dan
Dan, I think it is much simpler.
The chip has a 19:10 AR which is a good thing for wide screen movie capture. 3:2 can be easily cropped from it.
8,192 : 2x2,160 is 19:10 again.
Therefore, think you achieve the 45 pattern by only using the black fields in a checkerboard matrix. This checkerboard has 8192 columns and 4320 rows. Because only blacks fields are populated, the number of pixels is 8192 x 4320 /2 or 17.7M. In order to communicate to the "stupid" public, Sony had the choice between 4096x4320 and 8192x2160. And guess what? They took the latter. IMHO, that's it.
The pixels are square and probably aligned by a half pitch in odd columns, like in a brick wall turned 90.
Moreover, it explains why the article mentions that the resolution can be extrapoated to 8192x4320. Which is nonsense of course.
The proper resolution after demosaicing would be 5792x3055 and nothing else.
04-23-2011, 06:57 PM   #18
dosdan's Avatar
Falk, I understand what your saying, but why a "checker board"? Isn't the QE being seriously compromised if only half the squares are "black" (sensels)? Why can't all the squares, on the 45-orientated board, be "black"?
Dan.
04-24-2011, 12:56 AM   #19
falconeye's Avatar
Dan, I meant somethig different from what you understood.
Of course, the entire board is filled. But the "positions" of sensels are registered like black checkerboard fields. Think of the coordinates of bricks in a brick wall (where bricks are square). Horizontally, you have twice as many brick positions as there are bricks in a row. I think the Sony sensor has a similiar brick layout but turned 90.
Alternatively, "black" checkerboard fields could be rotated 45 and grown by Sqrt(2) to make "white" fields disappear.
04-24-2011, 03:26 AM   #20
thibs's Avatar
Maybe more info here:
sonyalpharumors | Blog | Sony shows a 18 Megapixel sensor with 120 fps
Which completely contradicts Ogl comments btw.
04-25-2011, 02:23 AM   #21
falconeye's Avatar
QuoteOriginally posted by thibs Quote
The interesting bit is the reference to the Sony ClearVid 45 pixel layout. As described here: http://www.sony.co.uk/res/attachment/file/78/1237477501978.pdf
Sony tries indeed to sell the 45 layout as providing more effective pixels which, of course, is marketing BS.
04-25-2011, 06:33 PM   #22
Class A's Avatar
Are you not regularly taking images with the camera rotated by 45 to double your chip area and then use horizontal interpolation to double the horizontal resolution?
Boy, this document contains the worst marketing BS I've ever read.
04-29-2011, 07:57 AM   #23
wll
Is This the Chip ....
.... that Pentax will use in there up coming mirror-less camera u think ?
Do u think Pentax will hit the video thing hard and maybe have a articulating screen with that camera ?
wll
04-29-2011, 02:31 PM   #24
thibs's Avatar
I'd be very surprised.
04-30-2011, 09:03 AM   #25
QuoteOriginally posted by wll Quote
wll
I honestly don't think the people at the top have a clue.
Otherwise by now we'd have seen something as simple as manual controls in video mode on even the K-5 and the K-7 by now.
And oh yes a reliable and solid quality flash system.
mp, pentax news, pentax rumors, sensor, sensor from sony
K-5 uses Aptina sensor rather than Sony?? kales Pentax News and Rumors 20 11-24-2010 08:58 AM
Sony outsources some sensor production to Fujitsu deadwolfbones Pentax News and Rumors 10 10-02-2010 03:24 PM
K-x Sony Sensor vs K-7 Samsung Sensor karl79 Video and Pentax HDSLRs 9 09-23-2010 09:35 AM
New Sony sensor SNR on par with D3 FF! JohnBee Pentax News and Rumors 38 09-19-2010 05:19 PM
Will Sony supply the Sensor for future bodies? Reportage Pentax News and Rumors 10 06-22-2010 06:47 PM
All times are GMT -7. The time now is 10:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
