Originally posted by rparmar No need really if P-TTL was accurate. I use A mode on my Metz and it is significantly better than P-TTL.
Why not use Bulb?
HSS solves this problem and gives you flash as fast as you need... no limits!
Revolutionary: "radically new or innovative; outside or beyond established procedure, principles, etc."
Increasing ISO a stop or two is in no way "outside or beyond established procedure". I refuse to use words as re-defined by marketing departments.
You said it -
if P-TTL was accurate. How about legacy support for accessories other than lenses?
Bulb means I need a remote, or need to be with the camera. A timelapse/delay mode with a programmable shutter would obviate the need for a plugged in remote (with it's own set of batteries to worry about), and keep the seals in the body intact.
HSS is great if you are using an external flash - often I am not - tend to use the onboard for fill, and have to stop down or use filters when shooting shallow dof.
Or I am outdoors, and don't have enough power in the af-360 for the range I am working with.
Originally posted by mattdm I do. I don't need my file sizes doubling without a meaningful increase in detail. I hope that if they go to this sensor, they implement something like Canon's sRAW and mRAW.
+1 for me. This is one of the things I really like with Canon workflow.
