Originally posted by Aristophanes No. Light transmission is a T-stop.
F-stop is purely the relationship between FL and effective optical diameter.
You are 100% right.
But I think I understand what Paul Ewins tried to say. And he has a point, wether you call it T-stop or F-stop (cf. below).
Originally posted by Paul Ewins The f-stop is primarily a measure of theoretical light transmission, not of DOF, so saying a 50/1.2 is the equivalent of a 75/1.8 is misleading. Fast lenses were made to transmit more light, not to give thinner DOF...
Paul Ewins makes a valid point and he basically uses T-stop and F-stop like synonyms. Which is ok in our context.
A wider lens' main purpose is to allow shorter exposure times or less sensitive film.
Therefore, one easily discards equivalence as it seems to apply to depth of field only. Which is a secondary concern as Paul writes corrrectly.
All my work and postings are to make knowledgeable photographers like Paul understand that equivalence applies to the primary concern of light gathering capability foremost (and then to every other concern up to diffraction as well).
This is also why equivalence is per camera, not lens.
So, the correct sentence would have to read:
Quote: saying a 50/1.2/ISO100 (APSC) is the (35mm-)equivalent of a 75/1.8/ISO200 is misleading.
And all of a sudden, one can see that it is not.
Both cameras capture an identical total amount of light, read, have equal speed. And therefore produce images of equal noise (noise is a property of light, not camera, one may have to know too).
We may discuss endlessly. But every single photographer who understands this is not a depth of field discussion makes me think that it was worth it.
