Originally posted by rawr the f4 17-40L, f4 24-70L, f4 28-105L and the 70-200 f4 as examples. Workhorse lenses, very good, very popular in Canonland, even amongst wedding photogs.
I don't use any of these lenses when i'm using my canon DSLRs, as small as f/4 lenses tend to be I prefer faster lenses because then you have the option of stopping them down when needed.
My typical set of lenses for my 1 series canon cameras are :
Carl Zeiss 21mm f/2.8
Carl Zeiss 35mm f/1.4
Voigtlander 58mm f/1.4 (sometimes I use the EF 50mm f/1.2L - I even use the EF 50mm f/1.0L from time to time)
Leica 80mm f/1.4 Summilux-R ( I also have a 85mm f/1.2L, but I rarely use it)
Voigtlander 125mm f/2.5 APO SLII Macro ( I have a EF 135mm f/2 L however i'm looking forward to buying the new Carl Zeiss 135mm f/2 APO to replace it*)
Canon EF 200mm f/1.8L ( I do have a Canon EF 70-200mm f/2.8L IS)
Canon EF 400mm f/2.8L ISII ( I often use this with a 2X extender to give me a 800mm f/5.6)
As you can see from the above lenses I have a strong preference for lenses with aperture rings and quality manual focus mechanisms.I also have the EF lens equivalents in situations where having AF is advantageous. But generally I select my lenses with high optical quality in mind, there aren't any zoom lenses that can really equal the performance of any of the primes I use. Though when i'm working with the Pentax 645D I use a mix of zoom and prime lenses, it really depends on what i'm doing.
*though it would be very interesting to compare the Zeiss 135mm f/2 APO against the Voigtlander 125mm f/2.5 APO SLII macro lens, they are both
phenomenal lenses with Impressive MTF's. Offhand, probably the biggest differences between them will most likely be vignetting knowing the track record of current Zeiss and Voigtlander lenses, which are both made by Cosina.
