Show Printable Version 236 Likes Search this Thread
06-23-2013, 01:04 PM   #2086
Cynog Ap Brychan's Avatar
Thank you to everyone who answered my question so eruditely. I learned a lot.
06-23-2013, 08:37 PM   #2087
QuoteOriginally posted by beholder3 Quote
That is exactly my point.
In reality you can nearly triple sensor pixel count plus double sensor size and maybe still get stuck with a meager +29% in effective resolution, depending on the exact camera/lens combination and where you look.
And down the drain goes the theoretical value which predicted for sensor size alone a +72% larger value.
True, but that doesn't make the theoretical discussion less useful. We need that as a baseline. Besides, it was a theoretical question, so it was a appropriate with a theoretical answer. What might, and might not happen in a given case, is not relevant in that regards.
06-24-2013, 11:40 AM   #2088
dadipentak's Avatar
QuoteOriginally posted by cmohr Quote
I'd like to see an "in camera" focus limiter setting.
That's a great idea!
06-24-2013, 06:57 PM   #2089
Sony's a99 has a focus limiter
06-24-2013, 07:37 PM   #2090
Digitalis's Avatar
QuoteOriginally posted by thibs Quote
I often end with f/22 which is a bit too small, probably. 1/ Schneider Super Angulon 75mm/5.6 2/ Schneider Symmar-S 150/5.6
I am familiar with these two lenses though I use the more up-to-date versions, at present I use the Schneider 150mm f/5.6 Super Symmar XL ASPH and the Schneider 80mm f/4.5 Super Symmar XL ASPH. From my experience the Super Angulon 75mm f/5.6 tends to perform better around f/16~f/22 range from what I have seen, resolving power does drop rather steeply towards the edges of the frame so be careful with the camera movements you use. The symmar -S 150mm f/5.6 should be perfectly usable from f/8-f/32... with that lens personally I would avoid stopping down past f/48. I would stop down to f/32 and tilt on the front standard to extend DOF if the subject demanded it - which is the beauty of large format, the ability to manipulate the field of focus.
06-25-2013, 10:50 PM   #2091
thibs's Avatar
Many thank, Digitalis, helps me much !
07-26-2013, 06:13 AM   #2092
Sony is rumored to be releasing the A79 with a 32MP APS-C sensor.
Will Pentax skip 24MP and go from 16MP straight to 32MP?
Will Pentax stay out of the MP race and go with a newer version of the 24MP (assuming Sony will offer one).
07-26-2013, 06:24 AM   #2093
If they can get the sensor, Pentax should go for the new 32 MP sensor. Think of the ability to crop for wildlife shooting? Also, file sizes would be huge.
Dale
07-26-2013, 06:27 AM   #2094
pdo
pdo's Avatar
Diffraction will kick in way early going to 32mp. I hope Pentax will go with 24mp.
07-26-2013, 06:41 AM   #2095
32 MPs sound interesting
07-26-2013, 07:13 AM   #2096
Clavius's Avatar
Why even develope a 32mp sensor if it would be heavily diffraction limited?
07-26-2013, 07:28 AM   #2097
gazonk's Avatar
QuoteOriginally posted by Clavius Quote
Then why use a 10mp sensor on a Nikon 1 series camera?
07-26-2013, 07:31 AM   #2098
I doubt it would be "diffraction limited"; its linear resolution is just ~1.41x higher than that of the K-5. Oversampling has some advantages, anyway.
07-26-2013, 07:38 AM   #2099
gazonk's Avatar
a 2x2-pixel binned 8mp high ISO mode would be great for such a sensor!
07-26-2013, 07:40 AM   #2100
Fogel70's Avatar
Because you get more advantages than disadvantages. Diffraction will not get worse on a higher resolution sensor, it will only be more noticable because of the higher resolution.
But a 32MP sensor will probably at least be better than 24MP on these:
- Higer dynamic range
- Lower noise
- Higher resolution (on large aperures where diffraction don't limit resolution)
- Better tonal range
- Less aggresive AA-filter needed (or less risk for moire if used without AA-filter)
All in all a 32MP sensor will improve IQ over 24MP, and diffraction will never make IQ worse on 32MP than with 24MP.
aps-c, body, k-5, k-7, k-7/k-5, pentax, pentax news, pentax rumors, reason, sensor, sony
Speculation: What if Pentax did not go FF but rather a 1.3x? brecklundin Pentax DSLR Discussion 36 08-13-2013 10:36 PM
Any speculation on how long... Tom S. Pentax K-5 & K-5 II 10 12-16-2010 09:19 PM
K-x price speculation SylBer Pentax DSLR Discussion 18 10-13-2010 12:29 PM
Small rant + speculation ilya80 Pentax News and Rumors 35 04-20-2010 11:42 PM
speculation about FA lenses on FF DSLR lpfonseca Pentax SLR Lens Discussion 19 11-05-2009 10:34 AM
All times are GMT -7. The time now is 10:33 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
