Originally posted by Clavius Yes, keep denying it without any arguments to back it up. I'm a father, so I'm used to that kind of debating.
I am sorry, but it's the "other camp" who has to prove that:
A. there is a serious issue with the K-mount that Pentax has to solve, and
B. there is no other way than a new mount.
Shifting the burden of proof while advocating such a dramatic change is not acceptable.
Originally posted by Clavius And how are those legacy lenses mounted to that Sony? Yes, with an adapter that increases the distance between the sensor and the lens. That distance increases the image circle too! Like holding a magnifying glass further away from your eye.
It's not about the lens diameter, it's about the image circle that those lenses cast on the sensor. Remember, DA lenses cast an image circle that is much bigger then neccesary for their corresponding sensor format to accomodate SR. Pentax Film lenses don't.
I am talking about the Sony Alpha, which is actually the good old Minolta AF mount. One can directly mount a Minolta legacy lens on an Alpha A900 or A850, and have in-body stabilization.
The Sony E mount does not have in-body stabilization. You are arguing without knowing such facts?
Originally posted by Clavius That's a matter of opinion. Backwards compatibility is a nice-to-have, but if it means sacrificing IBIS to go FF in favor of K-mount then it is absurd. Retaining IBIS however, would mean the Pentax FF would have something the Nikon D800 doesn't.
Until I'll see some proof that SR+FF is impossible with the K-mount, discussing this is pointless.
Originally posted by Clavius Moreover, if Pentax film era lenses lens turn out to be incompatible with FF-sensor-IBIS anyway, then there aren't even any lenses to be backwards compatible with.
Some vignetting in the extreme corners. The ability to disable SR for critical work. A slight crop. There are many other possibilities than changing the mount, even if this would actually be an issue.
Originally posted by Clavius The image circle gets bigger when the flange distance increases. Then a Pentax FF DSLR with SR can still use legacy film FF glass if there is an adapter (extension tube) in between. (Like your Sony example.) In other words, an adapter might still have to be used for legacy glass, even if the Pentax FF DSLR turns out to have the good old K-mount.
I'm afraid you don't understand some basic principles. Increasing the flange distance for a lens means focusing it on a closer subject. If you'd adapt a K-mount lens on a new-mount Pentax camera, the lens cannot be moved farther away from the sensor, not even 1mm - otherwise you'd lose infinity focus.
By your own words, this means a new mount will
not solve the (so far) imaginary FF+SR+legacy lenses issue.
Even on the Sony E, the role of that adapter (besides making mounting the lens possible) is to set the Alpha lens at the exact distance from the sensor, as it would be on an original Alpha camera. But, again, it wasn't about the E-mount but the Alpha.
