06-06-2011, 07:46 AM   #76
http://www.astroarts.jp/news/2011/06/03hoshinavi/pentaxgps.jpg
first review
anyone able to translate?
06-06-2011, 08:34 AM   #77
QuoteOriginally posted by Ishpuini Quote
Something is just dawning on me when reading through the discussion...
This unit interests me a lot since I was planning on doing some astrophotography (weather permitting) later this year when visiting Southern Argentina. And the location/heading data would be of great interest to me to locate the no doubt many landscapes I will be photographing along the roads.
Won't I be able to use it in the southern hemisphere at all? This would be a real disadvantage to me because I would expect to use this too on my next Safari(s), which is probably in Africa south of the equator too...
Tx in advance for clarifying this!!
Wim
GPS stands for Global Positioning System. Key word:
GLOBAL.
The NAVSTAR (original name for GPS) system was designed with a requirement for complete global coverage - a system that only worked "at home" would be useless for the Air Force and Navy.
Global Positioning System - Wikipedia, the free encyclopedia
However, augmentation systems that broadcast GPS correction data (local ionospheric conditions being the primary localized error source, satellite clock error is another but that's not localized) are local in scope.
WAAS only covers North America, and the scope where WAAS actually provides useful corrections (e.g. where iono information is valid) is even more limited than the signal coverage.
However, WAAS is only the difference between having around 10 meter potential error, and 5 meter or so potential error.
Edit: The European equivalent of WAAS is EGNOS. There's a Japanese equivalent too I believe. I don't think any augmentation systems are in use in the southern hemisphere, except for the classic local DGPS approach which few modern receivers support.
06-06-2011, 09:12 AM   #78
QuoteOriginally posted by dankoBanana Quote
it should be (as I found in the Telescope Reviews | Cloudy Nights forums)
Nice example on the 3 min shot (Pentax SMC DA* 16-50mm f/2.8 ED lens) at 16mm f/3.5 on the Milky Way.
On the second page 3x3 pictures:
Top row: upper-right corner
Middle row: central region
Bottom row: lower-left corner
Left column: untracked 3 minutes
Middle column: EQ mount
Right Column: AstroTracer
Clear Skies!
ccs_hello
06-06-2011, 10:19 AM   #79
v5planet's Avatar
If you can find a higher resolution image, I can give it a whirl, but right now the characters are too small for me to make out clearly.
06-06-2011, 11:57 PM   #80
This is what the content of the July 2011 issue summerizes (translated by google translate):
Cameras follow the motion of the stars of the body can only tripod "Pentax O-GPS1 with K-5 & K-r"
From Pentax, the item appeared on the motion to overturn common sense. O-GPS1 for the SLR, but GPS units that are equipped with the ability to perform the motion by moving the camera's image sensor. Is that what Tsutomu Makoto any attempt to deliver urgent reports.
There's an image of the unit on a K-5 with subscript: Only the motion of the tripod.
That's all that can be found on the site next to the image... not much...
Wim
06-07-2011, 03:26 AM   #81
Looks like someone in Japan should buy this magazine and repost the information. Or (better): Pentax should license this interesting review and repost it as well as full-resolution images.
Or (best) send me a K-5, some decent lenses, o-gps1 and let me take some pics (mag 6.5 sky, EQ-mount for reference...)
06-09-2011, 09:15 PM   #82
Arpe's Avatar
QuoteOriginally posted by Entropy Quote
GLOBAL.
It is still a fact that GPS works better in the North than the South as there are more satellites there. Some country's definition of "Global" doesn't equate to others'.
06-09-2011, 09:26 PM   #83
DAZ
DAZ's Avatar
QuoteOriginally posted by Arpe Quote
The US GPS (NAVSTAR) satellites are in polar orbits. There are just as many north of the equator as south. At the poles there are more at any one time then at the equator because they are in a polar orbit but north and south there has to be the same number. The only thing the controllers do is optimize the clocks so that the clock are the most accurate over some point on the globe but not one hemisphere over there other. At the moment it is rumored the clocks maybe being optimize for over Afghanistan.
DAZ
06-10-2011, 01:21 AM   #84
thibs's Avatar
I doubt this has a lot of influence. Of course, 3 satellites will not be precise. But between 5 and 8, I doubt it.
What can have a lot of influence though, is the geodesic system used. Usually, GPS internally use GPS84. But is wgs84 accurate in the part of the world you're in is a totally different question.
06-10-2011, 02:50 AM   #85
falconeye's Avatar
What DAZ said. But it doesn't matter which orbits they are in. Circular orbits never can cover more north than south. Consult the Kepler law to see why.
06-13-2011, 10:51 AM   #86
No, it isn't a fact. It is 100% wrong. https://gps.afspc.af.mil/gpsoc/PerformanceReports.aspx - Note that there isn't any significant north/south asymmetry.
GPS wasn't designed for North American civilian use - it has over time become so heavily used that it's operators are under a mandate to also support that role, but it was originally designed to improve the accuracy of weapons delivery (conventional and nuclear). Air Force bombers don't operate solely in the Northern hemisphere. Navy SLBMs don't either.
The only performance improvement Northern Hemisphere users may see over the South is that no one in the Southern hemisphere has started a system that is the equivalent of WAAS. Really, you're not seeing anything worse than I already do. (My hiking GPS is a Garmin Oregon, which has an STMicro Cartesio chipset - they STILL can't get WAAS working reliably...)
gps, pentax, pentax news, pentax rumors
For Sale - Sold: Genuine Pentax Leather Hand Strap for all Pentax DSLR's (Worldwide) kcmadr Sold Items 8 02-16-2011 09:02 AM
Pentax K-7 sales rank #9 at Amazon.com for DSLR's Mr Hyde Pentax News and Rumors 15 05-10-2010 11:42 PM
What do you think of Touchscreen for future Pentax DSLR's LeDave Pentax DSLR Discussion 34 03-25-2010 08:31 AM
Pentax K-7 GPS module dealrocker Pentax DSLR Discussion 3 02-06-2010 12:48 PM
All times are GMT -7. The time now is 12:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
