07-25-2011, 12:47 AM   #91
RonHendriks1966's Avatar
QuoteOriginally posted by eurostar Quote
I don't understand why DA*60-250/4 is always said to be full-frame. Mine is definitely not, it visibly vignettes in a film camera viewfinder.
O wow, we are just parrot's maybe.
07-25-2011, 03:21 AM   #92
Is that with or without the hood? Falconeye has said that it is full frame compatible, although he has not yet up loaded photos to show that fact.
07-25-2011, 03:45 AM   #93
froeschle's Avatar
[...] I don't understand why DA*60-250/4 is always said to be full-frame [...]
https://www.pentaxforums.com/forums/1046099-post134.html
https://www.pentaxforums.com/forums/1257659-post147.html
QuoteOriginally posted by falconeye:
[...] More on that if I find the time to compile the full article. [...]
Pentax 60-250 SDM Samples: Pentax SLR Talk Forum: Digital Photography Review
07-25-2011, 05:17 AM   #94
falconeye's Avatar
That's true. I updated the article with a few more details but still cannot find the time to write a full article.
-> https://www.pentaxforums.com/forums/1590833-post150.html
07-31-2011, 02:48 AM   #95
Ben_Edict's Avatar
QuoteOriginally posted by RonHendriks1966 Quote
This is interesting. Can a new 110D (with a larger sensor then Q) have a Q-mount but with a longer flancedistance. So the lenses for Q fit on 110D with an extensiontube, but the 110D lenses don't fit on Q. Or is this a strange idea?
How many different camera systems would you expect Pentax to support? It would be plain stupid, to add yet another system, after the Q was released. The Auto 110 D was just a prototype and proved either technically invalid or not marketable at that time. The same qas true with the unlucky MZ-D. The Philips sensor was way too expensive (only Contax used it and they are dead now for a couple of years). The whole concept of the MZ-D is now obsolete and outdated. If we can expect a larger sensor DSLR from Pentax its design would surely not be based on a 10 years old sample, which never worked fully.
Ben
07-31-2011, 02:57 AM   #96
Ben_Edict's Avatar
QuoteOriginally posted by Zygonyx Quote
Let' s add the Cosina 19-35mm f/3.5-4.5 which is used by quite a lot of Canon 5D and 5DII owner, a bunch of Zeiss (at least 8 lenses) and Voigtlander (at least 3 lenses) still for sale... even if they are to be discontinued in K mount.
For the zooms, it will depend on sensor resolution.
I hope for a start it could be contained to about 20-24 Mpix.
I my opinion; Ricoh would just need to refurbish the very good FA 24-90/3.5-4.5 boosted by a SDM engine. For a good start.
Zeiss has stopped K-mount lens productions months ago, probably because demand was too low.
The question is, why woulkd a photographer with a full-frame body opt for the poorly FA-J zooms? I cannot see any reason. Also, if I buy a pro-spec camera body, I want to look for the accompanying lenses from the body manufacturer, not from Sigma. I may buy some Sigma lenses, but I would still expect Pentax to deliver the basic set.
So, you have to think about the applications of a ff-FDSRL. For landcsape photography the existing line-up is viable - but then there is the 645D, which is aimed exactly at this clientele and is quite affordable (compared to some other MF digitals). So, for fashion, sports, studio set-ups many lenses are missing, no perspective correction lenses (shift, shift-tilt), no long glass, no fast long glass and very limited wide-angle choices.
I cannot see Pentax going into that direction. Perhaps that might change under the Ricoh umbrella.
Ben
07-31-2011, 07:33 AM   #97
Blue's Avatar
QuoteOriginally posted by Ben_Edict Quote
Ben
Gee Ben, we expect them to use the Philips sensor and the older AF system.
sarcasmsarcasm
07-31-2011, 07:44 AM   #98
Blue's Avatar
Ben
#1: Zeiss is a Niche market. Furthermore, if it wasn't for Zeiss having the AF line of lenses for the Alpha system, their sales would not even show up on the radar . . . oh wait, they don't anyway. The only other major manufacturers with mf lenses is Nikon with about 8 NIkkor including the 35/1.4. These can be bought from BH and Adorama. Then there are some by Cosina/Voightlander. I have felt that Pentax should maintain an assembly line for specialty products and run small batches of some items. manual focus lenses is one of those items i.e. the best of the best such as the A 15mm, K 18, K28/2, A 50/1.2, A* 85/1.4, A* 135/1.8., A* 200/2.8 and A* 200/4 macro. Put in A contacts on the K's and add Ghostless Coatings & SP. Those and a few other specialty items would keep the Specialty Assembly line going. It would be done in a sustainability fashion rather than with a goal of selling to everyone on the planet. However, selling them in different mounts might not be a bad idea.
#2: No one gives a flip about the FAJ lenses, well almost no one.
#3: The 645D is in a different ball game at $9-10K for the body. Plus the senor is somewhere between 24x36 and 645. I think many people with medium format don't have as many lenses as they did with 135 or digital 35. Pentax has been adding lenses to the 645D, but slowly which was in part due to them only releasing what was in the works and under the direction of Hoya who seems to have been in a holding pattern. We will see how that changes under Ricoh.
#4: Hassy has been sold recently so that should help level the playing field during the transition.
07-31-2011, 08:13 AM   #99
Douglas_of_Sweden's Avatar
That's a clever way to get a longer distance between lens and flash and reduce red eye risk.
07-31-2011, 09:41 AM   #100
thibs's Avatar
QuoteOriginally posted by Douglas_of_Sweden Quote
Agreed but most people here thought it was stupid because:
* it looks wierd
* Q is a bad idea which will be trumped anyway the sky is faling Pentax is dead.
08-01-2011, 03:16 AM   #101
BTW, does anyone know the registration distance for the Q?
08-01-2011, 04:38 AM   #102
Yep. I'd go so far as to say that it's such a good idea that it will be widely copied soon. And when it's ubiquitous it will seem perfectly normal.
08-01-2011, 07:29 AM   #103
I read something of 9 mm (or was it 9,2).
08-02-2011, 04:19 AM - 1 Like   #104
froeschle's Avatar
So, there was a Pentax bloggers meeting in Japan [...]
I wonder what is behind this event. Esp. as there is no real blogger scene in Japan. Or if I miss it, please point me to Japanese Pentax blogs (covering the event) ...
EDIT, ok, here is one [...]
Further reading :
d.hatena.ne.jp 1
d.hatena.ne.jp 2
d.hatena.ne.jp 3
sorryfull.blog8.fc2.com 1
sorryfull.blog8.fc2.com 2
detch.moe-nifty.com 1
detch.moe-nifty.com 2
www.schaft.net/n00bs 1
www.schaft.net/n00bs 2
www.schaft.net/n00bs 3
www.schaft.net/n00bs 4
mawari.cocolog-nifty.com 1
mawari.cocolog-nifty.com 2
mawari.cocolog-nifty.com 3
mawari.cocolog-nifty.com 4
shizuoka-sanpo.blogspot.com 1
shizuoka-sanpo.blogspot.com 2
( Google Translate )
08-02-2011, 07:57 PM   #105
RioRico's Avatar
QuoteOriginally posted by Douglas_of_Sweden:
9.2mm is what I found.
flickr, mirrorless, par, pentax, pentax news, pentax rumors, pictures, test
PENTAX auto 110 Ole Pentax Film SLR Discussion 2 02-07-2011 09:21 AM
Photo Rumors: Digital Auto 110 in 2011 kevinschoenmakers Pentax News and Rumors 60 01-22-2011 01:07 PM
Pentax auto 110 lens fourfivesix Troubleshooting and Beginner Help 5 01-08-2011 10:00 AM
Something nice for our Pentax Auto 110 users: Auto 110 lens database Adam Pentax Film SLR Discussion 3 09-24-2010 06:42 AM
Pentax Auto 110 inte Pentax Film SLR Discussion 49 06-21-2010 07:23 AM
All times are GMT -7. The time now is 08:26 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
