Originally posted by falconeye However, one has to acknowledge that a larger format is incredibly easier to focus, both manually and by an AF module.
But isn't that true only if you are talking about output sizes that do not take advantage of the MF format?
I see your argument, but if you are printing MF images at the same dpi settings as APS-C images (i.e., not at the same output size) then the AF accuracy required should be the same, right?
I see an analogy to exposure. In converting shooting parameters between formats, AFAIC, one should only change ISO values if one assumes that the larger format should be allowed bigger prints without a noise disadvantage. This is how "exposure" is traditionally defined, but I see a point for talking about identical output sizes in which case there wouldn't be a need to increase ISO, since a push in post would do the same without an effective noise disadvantage for the larger format.
N.B., the above "exposure" discussion involves the difference between increasing film ISO (which should increase effective sensitivity) and digital ISO (which more often than not is practically the same as pushing in post) and we do not need to go there, but I thought that there is a point to be made about either making the assumption that you can exploit the advantages of a larger format (i.e., print large without showing more noise and/or showing more AF inaccuracy) or not making that assumption.
