Originally posted by rparmar
No way to improve the K-5? I beg to differ.
- assignable Soft Button and Soft Switch
- configurable Soft Menu
- switchable "catch-in-focus" that works for AF lenses
- in-camera hyperfocal distance calculation
- focus bracketing
- improved P-TTL
- faster flash sync speed
- improved metering
- non-crippled KA-F mount for aperture coupling
- 110% viewfinder coverage with marked sensor range
- 1.0x viewfinder magnification
- tiltable back LCD
- switchable low-pass (AA) filter
- increased diopter range on viewfinder
- user modes that remember all settings
- a return to the superior K20D SD card compartment
- dual SD card slots
- ability to set dials to ISO in M mode
- ability to add aperture information manually (as focal length)
- option to not release shutter unless SR engaged
- option for shooting RAW with fewer megapixels
- tethered shooting with software access to camera parameters
- lower iso settings: 50, 25... (or built-in ND filter)
- full manual control and AF in video
- put green button back on top panel
- move LV button out of way of the other controls
- and then stop messing around with control placements for no good reason
Sounds like fun:
- I like that dial on the Q that allows for quick access to custom modes. Just give the camera a 5-way dial for custom USER modes, so they won't need to turn the LCD on when USER mode is selected.
- Bigger viewfinder... yes. Over 100% coverage... yes.
- Extra low ISO... yes
They cooked the K-5's low ISO, so it's possible to a point. - I agree with Improved P-TTL, but I'll one-up that and ask for TTL back as well. Or even better, there should be a radio-frequency trigger system in the camera that supports full communication. With that I'd drop the built-in flash. That will make room for the bigger viewfinder or the wireless electronics.
- A dedicated video button and much better video options and control than the K-5. I'd like to see the standard 30/60fps. 25fps is difficult to use.
- Tethered...yes.
They should fully support it from a technical standpoint and release the programming specifications for it to the general public (eg. tethering that can change the focus for focus stacking). That would save everyone unnecessary effort. I'm sure quite a few people would write software if the specs were completely open and available. Maybe Ricoh is better at bundled software than Pentax though? - Completely covered in magnesium-alloy with machined and engraved dials/buttons. The K-7/K-5 back panel is plastic as well as the flash, dials, and buttons.
- I like the "rule of thirds" focal points that Pentax uses. To augment that, maybe small clusters of multiple points could improve things. Say, each point has 9 sub-points and the side bars are taller and split up into 5 vertical bars.
- A non-crippled KAF2 mount.
- A more impressive battery grip. The internal battery should be accessible without removing the grip and I'd like to see more holding it to the camera than just the tripod screw. This is where I'd place the second SD card slot. The convertible nature of the K-7/K-5 should try to be followed. When I want something small I use the camera by itself. When I need more I use the camera with the grip.
I like a lot of your ideas, but I would personally not include a few for size and WR reasons. It looks like you are fond of the K10D/K20D more than the K-7/K-5, but I'm the opposite.
Instead of a screen that moves, they should sell a screen that works perfectly with the camera (4-5 inch). I wouldn't want extra points of failure and extra bulk from that. As I mentioned before I would put the second SD card slot in the battery grip instead of the camera itself. Not sure I agree with the green button placement. The current location seems fine in my opinion.
