Originally posted by RMabo This clearly shows that it isn't so much the autofocus technique in itself, as the AF algorithms and processing used.
It is easy to assume that rint motors are the fastest and best solutions, but in real life tests - it all comes down to the AF processing in the camera and not the technology in the lens.
OK, so the K10D already has the robust hardware which "isn't so much" the issue anyway, and processing
power in the K10D wouldn't be
less than Canon put in their 30D or 400D, etc., so you are putting a lot of weight into the K10D AF algorithm.
So...after the K20D firmware is perfected...hopefully Hoya pulled together some better engineers who can write a much more efficient, feature packed, and better firmware update for speeding up the K10D autofocus.
On person "in the know" has already said this might be possible.
