Originally posted by Clinton Is there any reason that if you removed the mirror box, that you couldn't mount a lens substantially inside the camera body if you wanted something with a shorter registration distance? Wouldn't that solve the issue of continuing the K mount, but allowing you to make lenses that don't protrude as far from the body?
It would put many limitation on the design of the camera and lenses.
- It would limit size of the glass in the lens, not making it possible to make cheap small fast wide angle lenses. Ultra wide angle primes have to be at least 25 mm longer as the whole lens cannot be fitted inside the camera.
- Would make design of zoom lenses more complex.
- Makes it more difficult to fit AF-motors in the lens. Smaller less powerful motors might be needed, making AF slower.
- Focus and zoom ring would be smaller on many lenses and it would be hard to fit other buttons on the lens.
- The camera has to include AF-motor and aperture mechanism for legacy lenses, making the camera more expensive.
- Not possible to use other brand legacy lenses.
