Originally posted by cali92rs Why not the GXR with a K-mount and K-5 sensor?
Because it doesn't make sense? Would be larger than a K-mount dSLR. And
much more expensive.
Originally posted by wjjstu Removing the mechanical shutter would not change the size of the camera.
No wide pancakes. Almost as big and heavy as my *ist DS. Do not want.
It is a K-5 internally, with a different body and shutterbox. And no AF and mirror/focal screen/prism. The K-5 sensor depends on a mechanical shutter.
Wide pancakes are feasible with protruding rear elements. Such lenses just wouldn't mount on a traditional K mount SLR.
This makes me think that the K01 mount has an additional hole or spare edge and dedicated K01 lenses have an additional pin or edge preventing them to be mounted accidentilly to a K-mount SLR. XS may be the designation for such lenses. However, I doubt it as the 40mm has no protruding rear elements.
Originally posted by Aristophanes I am not so sure initially it would be priced below an entry-level DSLR. It will come in higher.
Who needs the added complexity (and warranty headaches) of retractable lenses when you are the pancake lens brand?
I actually meant priced like an entry-level dSLR, not below. The EVF (I guess there is one) adds cost, the removed AF and focus screen/prism with mechanical calibration saves at least as much cost.
Originally posted by liukaitc image stablization???
I guesses (and argued cf. above) that it has EVF and SR. I concluded it from size comparison with a K-x. W/o SR, a K01 could be thinner than 59mm. W/o EVF, it could be lower.
