01-26-2012, 06:17 PM   #916
konraDarnok's Avatar
. A fully functional sensor shift would have to span 400,000m with 30m precision, or a relative precision of ~10,000:1.
You just doubled your number from 20cm to 40cm, and I don't know where you're getting these numbers. My 15mm DA moves maybe 0.5cm. My 43mm moves maybe a 1.5cm at the most to focus.
So, why did you reply that the sensor is lighter than the lenses?
Maybe it's a language barrier? I don't know what you are saying. What you're quoting there seems to imply a sensor would have more mass than a comparable lens groups would. I don't think that's true.
Something is just not communicating here.
01-26-2012, 06:24 PM - 1 Like   #917
jpzk's Avatar
@ falconeye
@ konraDarnok ...
I've been following this thread all along, not trying to interfere with any assumptions, suppositions, rumours and/or scientifically based rethorics but these last couple of posts (previous two) make me wonder where the thread is headed.
Bash me if you want but ...
Can you guys shake hands and move on ?
JP
01-26-2012, 06:25 PM   #918
1cm thick isn't all that much different from the 1.5cm thick DA 40mm that exists now. The point of using the same mount? Someone explain to me please.
01-26-2012, 06:28 PM   #919
QuoteOriginally posted by jpzk Quote
@ falconeye
@ konraDarnok ...
JP
I would, but I just don't know what we'd be agreeing to disagree about. I don't understand his criticism.
Anywho, if the 40mm XS ends up being a fixed lens with sensor shift, it would be prophetic
01-26-2012, 07:09 PM   #920
falconeye's Avatar
QuoteOriginally posted by konraDarnok Quote
My first number was for the DFA100WR. And quoted as such.
My second number was the required shift in a camera supporting the general case, taking into account that 180mm/200mm Macro lenses do exist.
I didn't double my number. It's two different numbers.
As for the language barrier: I am saying that the sensor shifts until it hits the body. And (cf. at numbers above) it will. And then, you need to shift the lens instead to make your camera work. And at that point, the sensor mass becomes irrelevant. I nowhere ever implied a sensor is heavier than a lens.
Overall, we are now at a point where we discuss. Something I didn't want. I'll stop it now from my side.
EDIT:
Didn't see JP's post. But to move on was my intention anyway
01-26-2012, 07:28 PM   #921
falconeye's Avatar
QuoteOriginally posted by wjjstu Quote
It is strange indeed. The DA 40 w/o hood and filter thread is just 12mm thick (with some space to the front lens). So, the DA40XS would just be a mechanical revision to make it 2mm smaller. But why shouldn't it work on a standard K mount? Soon we'll know what XS is meant to mean ...
One idea I had was an electric lens cap as it is something which bugs me if I am expected to put a Pentax with the DA40 into a pocket: to first put the lens cap on. Then, it could be (theoretically) that the electric lens cap on a standard K mount wouldn't open. Later XS lenses then could even retract with the lens cap close command.
01-26-2012, 07:37 PM   #922
pcarfan's Avatar
I think the new 40mm is optimized for CDAF to be competetive with other systems.
01-26-2012, 09:25 PM   #923
hcarvalhoalves's Avatar
QuoteOriginally posted by Steelski Quote
Few more Pentax K-01 details | Photo Rumors
The camera is designed by a famous designer
The new 40mm f/2.8 pancake lens is less than 1 centimeter thick and my understanding is that it will work only with the new K-01 body
The Pentax K-01 and the 40mm lens are covered with some kind of rubber-like material for better grip
The K-01 will have an external mic output for video recording
And the plot thickens...
Damn, if this thing came all rubberized and weather-sealed, that would kick ass. I just hope it's EVF or whatever (if it ever ships with one) doesn't suck. Back LCD only is a no-no.
01-26-2012, 10:21 PM   #924
ogl
ogl's Avatar
It seems K-01 will be weather proof camera. I will buy it as travel kit with 40 lim.
I think that the price will be more than USD1000.
01-26-2012, 10:23 PM   #925
ogl
ogl's Avatar
hybrid K-mount ?
01-26-2012, 10:55 PM   #926
Laurentiu Cristofor's Avatar
If they will also make rubber lenses, this has the potential of cornering the adult toys market.
01-26-2012, 11:42 PM   #927
Zygonyx's Avatar
QuoteOriginally posted by ogl Quote
You seem to know quite a bit about this novelty. So it would really range up the K-5's price and quality levels ?
01-27-2012, 12:08 AM   #928
I think you've got it backwards. It'd be a much simpler and cheaper camera. SLRs are the complex machines that require calibration to work properly. You'd eliminate the mirror box, phase detection system, and the lens communication for software that would control some kind of linear actuator -- like a voice coil or hypersonic motor. All of the other functions that were achieved in hardware would be virtualized.
I'm afraid I've got it right. Don't forget the idea was to have this and the classic lens AF system.
It cannot be simpler and cheaper. By itself it does not eliminate anything, it's a redundant system added to an already complex camera (be it SLR or mirrorless).
So even if it were a simple, inexpensive mechanism it means added complexity and cost, it will also add bulk. But is it? I'm afraid not... it must be very precise, fast and have a larger moving range than you'd expect. Falk explained why.
Contax... more or less had to do it (to offer AF with MF lenses). But why would Pentax? Why would they put such an unneeded kludge in their cameras? There would be no value added to the current system, since it's already perfectly capable of autofocusing...
1 cm thick lens? Looks difficult to mount/unmount it...
01-27-2012, 12:11 AM   #929
Kryscendo's Avatar
If the camera is indeed a brick shape, I would be weary of the FedEx guy throwing it through my window.
01-27-2012, 12:19 AM   #930
QuoteOriginally posted by Kryscendo Quote
I am kind of like that notion, really. A shockproof mirrorless camera. Still, I really hope they come up with something decent for using lenses from other brands. Moving sensor or collapsible mount would be great. A weaker AA filter on the sensor would be good, as well.
camera, k-01, k-01 mirrorless camera, mirrorless, pentax, pentax news, pentax rumors, rumors
Is the new pentax mirrorless coming out tomorrow? justtakingpics Pentax News and Rumors 12 07-26-2011 06:22 AM
There may not be a 2nd mirrorless camera rustynail925 Pentax News and Rumors 5 06-29-2011 05:36 PM
Mirrorless Camera--Good or Bad? InStitches49 Troubleshooting and Beginner Help 15 11-10-2010 10:15 PM
[RUMOR] Canon's First Mirrorless Camera! jct us101 Non-Pentax Cameras: Canon, Nikon, etc. 12 09-14-2010 08:08 PM
New Pentax: K-5, K-r and Mirrorless models coming JohnBee Pentax News and Rumors 32 08-08-2010 01:57 AM
All times are GMT -7. The time now is 01:30 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
