01-27-2012, 12:56 AM   #931
QuoteOriginally posted by LFLee Quote
"The new 40mm f/2.8 pancake lens is less than 1 centimeter thick and my understanding is that it will work only with the new K-01 body"
-- why old lenses can work on this body but the new 40mm don't wok with older body? hm.... it is can't AF on old body?
what could be the reasons?
Probably because the new lens protrudes into the body.
There not being a mirror in the K-01, lenses can be mounted a lot closer to the sensor, but the actual mount must be at the same distance as in a DSLR if the camera has to be compatible with the existing K-mount lenses.
So if you make a lens that sits half way into the camera body (where the mirror is in a DSLR), you can attach it to a K-mount and make it stick out much less (because only half sticks out). Of course, you could mount such a lens onto a K-mount DSLR if it weren't for the mirror which will be in the way.
Hence this lens will be K-mount but only for the K-01.
Wim
01-27-2012, 12:59 AM   #932
Clavius's Avatar
QuoteOriginally posted by Ishpuini Quote
Wim
If there was a way to lock the mirror up, such a lens could also be used on a K-mount dslr.
Forgetting that mirror lockup would be complete horror though.
01-27-2012, 01:00 AM   #933
So if you make a lens that sits half way into the camera body (where the mirror is in a DSLR), you can attach it to a K-mount and make it stick out much less (because only half sticks out). Of course, you could mount such a lens onto a K-mount DSLR if it weren't for the mirror which will be in the way. Hence this lens will be K-mount but only for the K-01.
makes sense, somewhat. move the mounting halfway into the lens.. but then again, wouldn't that design make actually mounting the lens into the camera and manual focusing a lot more difficult?
01-27-2012, 01:13 AM   #934
nah
holy moly, 63 pages now...
01-27-2012, 01:13 AM   #935
eurostar's Avatar
The only puzzle is why to choose the 40mm, that is very slim as of now, to be adapted to sit halfway inside the mount, losing just a few millimetres of thickness, when they could have done it with the 35/2,4 (or a new 30mm lens) that would be much useful as a fixed kit lens and would show much more deeply the advantage of not having a mirror. The ideal would have been a new, symmetrical version of the 24/2.
01-27-2012, 01:25 AM   #936
Asahiflex's Avatar
I guess the designer wanted to retain the 'brick shape' as much as possible. The DA40 is indeed already one of the smallest pancakes; I guess he wanted to make it visually the smallest of them all despite the still large K-mount to sensor flange.
Anyway, we're up to some very interesting news in the coming days. I hope for an early leak
01-27-2012, 04:19 AM   #937
ihasa's Avatar
QuoteOriginally posted by Alizarine Quote
The outside of the mount itself could, if it projects a few cm past the body, have a manual focus ring with electronic linkage to the lens. Having the XS lens mounted *within* the throat of the lens mount might allow it to be really well sealed as only the front element would be exposed...
XS = eXtremely Sealed? Digital Nikonos? The rubber coating and rumoured deep recessing of the kit lens suggests this model might be beyond 'ruggedised'....
01-27-2012, 04:33 AM   #938
gazonk's Avatar
QuoteOriginally posted by ihasa Quote
Now that would really be cool!
01-27-2012, 04:36 AM   #939
QuoteOriginally posted by eurostar Quote
I would bet that the rest of the DA limiteds would be given the same treatment in the future for this camera. Clearly, they are going to have some kind of in lens motor, if they are going to be able to be used for video. Pentax is then going to sell the camera as a unit, saying to purchasers that the camera combined with various (available) lenses is quite small, even if the body itself is just a little larger than NEX or similar cameras.
01-27-2012, 07:31 AM   #940
Banned
Some more Pentax rumors (full frame DSLR, mirrorless camera)
The Pentax full frame DSLR and mAPS-C mirrorless camera rumors are back. I received several new tips on those products.
After it got acquired by Ricoh, Pentax is reportedly determined to provide a full range of cameras, including a new full frame DSLR and the upcoming K-01 APS-C mirrorless camera. A Ricoh representative recently said that they “will plug a gap in the market” in 2012. The full frame Pentax camera is rumored to be announced later in 2012 (either in May or for Photokina in September).
The new Pentax K-01 mirrorless camera is supposed to be build like a brick, literally - you should be able to place on a table in landscape or portrait position without a tripod. Pentax has said in the past that they like to do things differently:
"if we decide to do something in this respect has to be different, and it is not easy in the current context, to do something that is different and good…”
All Pentax FA lenses will work on the new K-01 with the exception of few models.
Some more Pentax rumors (full frame DSLR, mirrorless camera) | Photo Rumors
01-27-2012, 07:36 AM   #941
Asahiflex's Avatar
Just a reiteration of old rumors, but maybe the rumors are getting firmer
01-27-2012, 07:44 AM   #942
konraDarnok's Avatar
QuoteOriginally posted by jogiba Quote
The question is why? What would exclude some FA models from functionality?
01-27-2012, 07:50 AM   #943
Asahiflex's Avatar
QuoteOriginally posted by konraDarnok Quote
That should probably have read "AF" and not "FA". There is the old SMC Pentax AF 35-70mm f/2.8 which only worked with the Pentax ME-F.
(BTW: the ME-F was the first mass produced AF SLR, despite the success of the Minolta 7000).
01-27-2012, 07:58 AM   #944
QuoteOriginally posted by Asahiflex Quote
You think? That's a pretty esoteric lens. I just don't that would even be worth mentioning.
01-27-2012, 08:11 AM   #945
Asahiflex's Avatar
Indeed, but stating "the K-01 works with every Pentax AF K-mount lens" would then be false.
camera, k-01, k-01 mirrorless camera, mirrorless, pentax, pentax news, pentax rumors, rumors
Is the new pentax mirrorless coming out tomorrow? justtakingpics Pentax News and Rumors 12 07-26-2011 06:22 AM
There may not be a 2nd mirrorless camera rustynail925 Pentax News and Rumors 5 06-29-2011 05:36 PM
Mirrorless Camera--Good or Bad? InStitches49 Troubleshooting and Beginner Help 15 11-10-2010 10:15 PM
[RUMOR] Canon's First Mirrorless Camera! jct us101 Non-Pentax Cameras: Canon, Nikon, etc. 12 09-14-2010 08:08 PM
New Pentax: K-5, K-r and Mirrorless models coming JohnBee Pentax News and Rumors 32 08-08-2010 01:57 AM
All times are GMT -7. The time now is 08:05 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
