Originally posted by Quicksand Serious questions:
(1) Is there anyone who holds a DSLR with a long, heavy lens using only one hand?
unless you are Mr. Universe.
Quote: (2) Is there anyone who uses their face to support the weight of a DSLR?
nope. your face can't hold or carry a dslr. unless you are an alien.
basically, carrying or using long heavy lenses is always a challenge, regardless if the body is small or lighter. in which case, more often a bigger and heavier dslr body is better to counter-balance the weight of the large lens in front. handholding it with both hands is tough enough. that's why you see most people use tripods or monopods with such combo.
your face is more for stabilization but would still be susceptible for camera shake since the camera and lens would still rely on how stable your overall handling is. as long as you are shooting above 1/200, you don't have to worry about sticking your face on the camera. VF helps a bit with stabilization while shooting with longer heavier lenses below 1/200. but it will not completely eliminate movement. above 1/200, it makes no difference whether you stick your face on the VF or focus using the screen display.
for me, it took a bit of getting used to the habit on relying on the screen display. so far, I manage to survive and able to take pictures without having a viewfinder. if I feel like I need to use a VF, I can always use a hoodman loupe. whether it's for stabilization or for better viewing (since the screen display during daylight shooting is susceptible to glare or poor contrast).
the biggest selling point of the K-01 is the price you have to pat for K-01 sensor, mirrorless concept, faster AF operation and great video capabilities (possible even longer and better heat tolerance). you may lose the OVF and battery life. if those are big deal for you, then the K-01 is not for you. as for me, using the hoodman would be much better than viewing on the small OVF. just my cents.
