Show Printable Version 4 Likes Search this Thread
03-01-2012, 01:56 PM   #31
Anvh's Avatar
QuoteOriginally posted by Kennod Quote
Actually this upgrade is fixing issues with SDXC cards, not SDHC. This is a welcome fix for me because I used to get image corruptions after deleting RAW images in camera using a 64GB card.
Probably only impacted a few of us but very welcome none the less.
SDXC and SDHC is all the same
03-01-2012, 01:58 PM   #32
Yep it's true.
PK_Tether 0.6.4 (latest) doesn't work with the K-X anymore after the 1.03 firmware upgrade. Going back to firmware 1.02 doesn't remedy the problem. However, using an older version of PK_Tether (0.4.5) still works with the K-X after the upgrade.
A benefit of using the latest PK_Tether (0.6.4) is to have access to the DEBUG mode, but unfortunately that's been disabled, in fact, the launching PK_Tether causes an error.
Had a bunch of AF lens that were helped from some FF/BF fine tuning and now that's not possible.
(Really angry gal)
03-01-2012, 02:02 PM   #33
cbope's Avatar
I updated my K-5 to 1.13, and PK_Tether 0.6 still works. Have not downloaded or tried 0.6.4 yet.
Edit: Downloaded 0.6.4 and it's working. Have not tried debug mode though (and not interested).
03-01-2012, 02:10 PM   #34
Hey! Problem solved! I tried upgrading to firmware 1.03 again then did a reset and now the DEBUG mode works again!!
03-01-2012, 03:06 PM   #35
jpzk's Avatar
The firmware cannot be saved "as usual"
I've tried dowloading the firmware(s) both from the links provided here and from those at Pentax Canada ... instead of being "saved" (as it usually does) the file wants to install itself, so the computer displays a warning about the file being "uncommonly downloaded" ??? and that "it can harm your computer".
I've tried a few times but I always get the same response from the computer; it just won't save.
Any idea what I am doing wrong ?
Thanks,
JP
More Pentax news at: New DSLR Firmware Released (v1.13/12/03) - Pentax Camera News & Rumors - PentaxForums.com
03-01-2012, 03:19 PM   #36
jpzk's Avatar
This must be a new thing after a Windows update (automatic) because it now asks/warns that a specific software is trying to get dowloaded and, because it is "uncommonly dowloaded" (by other users on the Web), should not be used !!
This is the first time I receive such a warning ever since I've downloaded firmwares from Pentax, circa K10D !
Anyway I have these now on my desktop:
FWDC209B.BIN (and a Readme file) for the K5 - 10,752 KB
and
FWDC204B.BIN (and a Readme file) for the K7 - 10,752 KB
So, I suppose this is all of "it" for both cameras.
JP
03-01-2012, 04:40 PM   #37
I have had a K-x for about 18 months now and have always been afraid of updating the firmware incase I 'bricked' it. Tonight I 'bit the bullet' and tackled it. First of all I charged up a set of batteries to ensure the camera would not shut down during the update. When I downloaded the file from Pentax I asked it to open it which produced a response from windows 7 that it could not run the program (after warning me that it could harm my computer). I ditched this file into the recycle bin.
Downloading it again I saved it to my Desktop. Right Clicked the icon and opened the file which produced two files on my desktop.....the Read Me File and the BIN file.
I then formatted an SD card in the CAMERA, removed it and inserted it into the SD card slot on the computer.
The next step was to open the SD drive on the computer whcih showed the DCIM folder on the SD Card. Then drag the BIN file from the Desktop into this folder to copy it to the SD drive (NOT into the DCIM folder). The end result is an SD Drive folder with two icons on it....the DCIM folder and the BIN File.
Remove the SD Card from the computer and with the camera switched off insert the card into the camera. Switch on the camera whilst holding the MENU button and follow the instructions on the LCD screen of the camera as per Read ME Instructions. Much easier than I thought it would be.
I cant comment as to what it has done to the functions of the camera, but it appears to be ok.
I know many of you are very knowledgeable on this forum, but I thought I'd impart my experience as a completely inexperienced and wary amateur to updating the firmware for the first time
03-01-2012, 08:11 PM   #38
Someone asked this earlier in the thread but I didn't see anyone answer.
Does anyone know if you have to do each firmware upgrade, or is the latest all inclusive?
03-01-2012, 08:34 PM   #39
VoiceOfReason's Avatar
The latest should be all inclusive.
03-01-2012, 08:56 PM   #40
Anvh's Avatar
QuoteOriginally posted by jpzk Quote
and
JP
Did you download the Windows option the EXE file?
Next time just download the Mac version, it's a zip file and much easier to handle and it should not give you a warning.
Another good thing is that if you unpack the zip it gives you an warning when it's missing something so that means you didn't download it all.
If it doesn't give you a warning then it's all fine.
03-01-2012, 08:58 PM   #41
Anvh's Avatar
QuoteOriginally posted by k2112S Quote
Firmware isn't really an upgrade but more a replacement.
So instead of adding the new parts you actually replace everything that means you just need to download the llatest version.
03-01-2012, 09:22 PM   #42
philbaum's Avatar
QuoteOriginally posted by DaveXT Quote
Is that the DCIM folder? Please excuse my ignorance I have upgraded the firmware on many devices over the years but have not come across these terms before.
No, the DCIM folder is itself in the root directory, but if you put the upgrade file in that folder, the upgrade file will not be in the root directory.
03-02-2012, 03:27 AM   #43
pop4's Avatar
QuoteOriginally posted by felixkh Quote
Having a lens attached to the body when doing firmware upgrade does not mess up the firmware upgrade. No issues with lens on body.
No issues with upgrading the camera without a lens attached either.
03-02-2012, 03:53 AM   #44
gazonk's Avatar
Yes, it came with some recent Win 7 update. It's the newest in dysfunctional Windows security software, it's really a PITA (It's hit a program I make too, so Microsoft has already stolen a few hours of my life that I had to spend on telephone support).
03-02-2012, 04:24 AM - 1 Like   #45
QuoteOriginally posted by gazonk Quote
I have learned from this many years ago.
Now I have automatic updates turned off and when I am ready to do an update I always, always make a spare Clone of the prime HDD first. This way I can swap the cloned HDD back into the machine if anything has gone "KAPUTT". I use removable HDD trays for this to make it easy.
Greetings
firmware, pentax news, pentax rumors
In case you did not know, 645D Firmware 1.11 is available Yamanobori Pentax Medium Format 0 09-07-2011 07:31 PM
645D firmware 1.11 released Yamanobori Pentax Medium Format 0 07-13-2011 08:30 PM
645D pixel mapping, pre & post V1.02 firmware update observation mikeyscope Pentax Medium Format 2 05-25-2011 01:39 AM
New 645D firmware Shuttershane Pentax Medium Format 11 01-17-2011 02:42 PM
New Firmware Officially Posted (1.02 K-5, 1.01 K-r and 645D) nixcamic Pentax News and Rumors 9 01-05-2011 08:47 PM
All times are GMT -7. The time now is 05:36 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
