Originally posted by ElJamoquio Picking nits, but you can't have both the same perspective on FF and APS-C *and* 1:1 focusing. Macro on FF is a larger projected image than macro on APS-C.
In all other industries involving macro/microscopy nobody talks about there image being 1x. Because as soon as you print your picture it isn't 1x (unless you print at 24mm x 35mm from FF). I am just saying you have the exact same focusing distance when making the exact same picture with a FF camera with 150mm lens focused at 1:1 and apsc with 100mm (lens is obviously focused at less than 1:1).
My initial comment was that the 100mm perspective gives the exact same image as a FF and 150mm.
The poster disagreeing was talking about working distance being different. As I explained getting the same magnification (images printed to the same size with same perspective) it is the exact same working distance.
The discussion was all about my original comment. Not whether the perspective of FF at 1:1 and apsc at 1:1 lens magnification gives the same perspective.
Not whether the 100mm on apsc focused at 1:1 is the same as 150mm on FF focused also at 1:1. Sure the image on the apsc when printed to the same print size as FF and 150mm will have higher magnification regardless of both being focused at 1:1. But you have to understand magnification.
But when comparing the two you have to talk about perspective. Final magnification relies solely on how large you can suitably print. A image from a 645D focused at 0.5x is capable of larger magnification than a picture from a K7 at 1x. Because you can print larger. This is basic logic.
