03-05-2012, 02:31 AM   #1
fs999's Avatar
Sigma APO Macro 180mm F2.8 EX DG OS HSM
A new lens is announced by Sigma : APO Macro 180mm F2.8 EX DG OS HSM.
SPECIFICATIONS
Lens Construction....................19 Elements in 14 Groups
Angle of View............................13.7
Number of Diaphragm Blades...9
Mininum Aperture.....................f22
Minimum Focusing Distance.....47 cm / 18.5 in
Filter Size (mm)........................86
Maximum Magnifications..........1:1
Dimensions
(Diameter x Length).................95 x 203.9 mm/3.7 x 8.0 in
Corresponding Mounts............Sigma
................................................Canon*
................................................Nikon*
................................................Pentax*
................................................Sony alpha*
................................................Sony Nex*
This is the world's first 180mm macro lens incorporating a magnification ratio of 1:1 and a large maximum
aperture of F2.8. It benefits from Sigma's original Optical Stabilizer function and the wide F2.8 aperture allows
faster shutter speeds for narrow depth of field, enabling photographers to emphasize the subject. Three FLD
("F" Low Dispersion) glass elements provide excellent correction for color aberrations. This lens incorporates
Sigma's floating inner focusing system. This minimizes aberrations which occur as shooting distances change, and
enables stable rendering of the image from infinity to 1:1 magnification. The Super Multi-Layer Coating reduces
flare and ghosting and provides sharp and high contrast images even at the maximum aperture. Equipped with
Sigma's own propriety OS (Optical Stabilizer) system, this lens offers the use of shutter speeds
approximately 4 stops slower than would otherwise be possible*, enabling handheld close-up photography.
The incorporation of HSM (Hyper Sonic Motor) ensures quiet and high speed autofocus as well as full-time manual
focus capability. This lens has a rounded 9 blade diaphragm creating an attractive blur to the out of focus
areas of the image. At 1:1 magnification, this lens has a focusing distance of 47cm/18.5in, which is a greater
working distance than shorter focal length macro lenses. This is advantageous when taking pictures of highly
sensitive subjects such as butterflies and insects. Attaching Sigma’s optional Tele Converter's allows
photographers' to shoot with an even greater working distance or with a magnification ratio larger than 1:1.
* added by Sigma Germany.
03-05-2012, 03:19 AM   #2
Mareket's Avatar
DoF at F/2.8 and 1:1 macro is apparently half a millimetre @.@
03-05-2012, 03:27 AM   #3
Vylen's Avatar
Minimum focusing distance of almost half a meter sounds like it would be a bit troublesome to work with?
03-05-2012, 03:33 AM   #4
QuoteOriginally posted by Vylen Quote
It does. It seems much harder to stabilize a longer macro lens for handheld work. On a tripod with rails, this thing would be amazing. The upside of a longer focal length for macro is you don't risk scaring your subjects so much, in the case of bugs and that kind of thing.
I suppose no word yet on what this beast will cost?
03-05-2012, 03:52 AM   #5
Mareket's Avatar
Would this be useful for bugs and moving things? Surely you're going to need to focus stack like a demon if you want anything in focus?
03-05-2012, 04:23 AM   #6
timh's Avatar
I guess Sigma made all the really useful lenses it could think of, then made all the fun lenses it can think of, and this is the answer to "OK, so what now?"
03-05-2012, 04:35 AM   #7
Digitalis's Avatar
the Sigmaphoto website only has the Sigma lens mount listed for this particular lens.
03-05-2012, 04:35 AM - 1 Like   #8
QuoteOriginally posted by timh Quote
nah, there's heaps of useful lenses they still need to make for pentaxians. Bring back the 100-300 f/4 for starters, and/or start making the 120-300 2.8 in k mount.
03-05-2012, 05:13 AM   #9
JinDesu's Avatar
I want one, to say the least.
Didn't know this was coming in k-mount.
03-05-2012, 05:32 AM   #10
falconeye's Avatar
QuoteOriginally posted by Mareket Quote
There is a misunderstanding of what defines depth of field here.
If you go for a given magnification (like 1:1), the focal length is factored out of the equation. A 35mm and a 180mm macro at the same F-stop deliver exactly the same DoF at 1:1 magnification. To see what it is, enter twice the focal length as focussing distance into DoF calculations.
03-05-2012, 05:35 AM   #11
falconeye's Avatar
QuoteOriginally posted by fs999 Quote
To ba fair, Sigma Germany added the 150mm Macro for K mount too. But it never appeared and they now removed it.
03-05-2012, 07:26 AM   #12
fs999's Avatar
So you suppose there won't be a Canon and Nikon version either ?
Hope well and have well
03-05-2012, 11:20 AM   #13
Mareket's Avatar
Aaaah ok. Why is this? Does the relevance of focal length scale back to normal as you approach less dramatic magnifications? And lenses don't focus down to twice their focal length do they? That'd mean the 180mm would focus down to 36cm.
03-05-2012, 05:52 PM   #14
Banned
aperture of F2.8.
Only the last part about the f/2.8 aperture is the novelty. Tamron already had a 180mm 1:1 macro, but maximum aperture was f/3.5.
The OS might make sense on this lens as it may be more effective than SR for macro work.
I am surprised they don't mention the weight in the specs. It might approach 1.4kg. It will be interesting to handle it on the NEX.
I expect its cost to be above $1600. Maybe around $2000.
03-05-2012, 11:13 PM   #15
Digitalis's Avatar
QuoteOriginally posted by Laurentiu Cristofor Quote
well in it allows one to use a 2X Teleconverter and still be able to use AF. But at high magnifications IF lenses still lose some light so there would be a point where the accuracy of the AF would become rather questionable.
I happen to have the Sigma 180mm f/3.5 APO EX lens and while it isn't optically as good as the FA*200mm f/4 ED [IF] Macro which I also own at least it is more compact than the Pentax lens is, while being 0.5 of a stop faster.
180mm, aperture, distance, f2.8, hsm, lens, macro, magnification, os, pentax news, pentax rumors, sigma
For Sale - Sold: Sigma APO Macro 180mm F3.5 EX for Pentax dgaies Sold Items 5 11-05-2011 05:36 AM
For Sale - Sold: PENTAX-D FA 50mm F2.8 Macro and Sigma 180mm F/3.5 EX DG IF APO Macro Lens LenWick Sold Items 9 06-16-2010 11:09 AM
For Sale - Sold: Sigma 180mm f/3.5 EX DG IF HSM APO Macro Lens MikeDubU Sold Items 15 06-02-2009 11:58 AM
Sigma 180mm f3.5 APO EX DG HSM? dadipentak Pentax SLR Lens Discussion 5 12-20-2008 12:52 PM
All times are GMT -7. The time now is 12:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
