01-10-2008, 05:17 PM   #1
If we take a look at what WendyB wrote in this cryptic title:
It's official. K** "H"D
Doesn't everything fall into places?
And WendyB also seemed to be under NDA and has tested the prototype.
Also if you use a 12MP CMOS sensor as a baseline, extend it to 16:9 format, and you would get 14MP! So it can have higher pixel count but with same noise performance as D300 as they would have the same pixel density.
PS: Hmm.... what have I done? My post is supposed to be a follow up and post #14, why is it appearing as post #1?
Larry's "From Dubai:" post is supposed to be the starting post!
01-10-2008, 10:57 PM   #2
More Dubai disclosed K20D features
From Dubai:
The new K20D will have live view and can preview the photo on the viewfinder. This was done by installing a small LCD monitor in a viewfinder meaning an EL display developed by samsung, like samsung did it on their previous SAMSUNG PRO-815 model. The live view is also available on 3 inch LCD.
There are two types of AF mode and they said that they have improved their AF performance. The AF uses a new Contrast Method and will not use their existing AF method (by Distance Measuring Mode).
I haven't seen any info on whether they even realize that predictive/tracking autofocus is whats incredibly important to be done right on the K20D. At least as good as the D300 or similar should have been the standard of performance before even accepting the final product. Hopefully predictive/tracking will be one of the 2 types.
In continuous drive mode, this new model can shoot 1080p full HD size, up to 14-16 shots..while Nikon's D3 can only shoot 510p up to 11 shots and unknown "p"(maybe 200p more than K20D) and up to 10 shots on Canon's 1D MarkIII. It also can shoot 3fps 12bit/14bit RAW file while Nikon's D300 only can shot 2.5fps 14bit RAW file. The GX-20 can record 720p video and maybe the K20D also has that feature..
The sensor will be 14MP CMOS APS-H sensor (approx 30mm X 16mm) being a little bit widescreen
Better SR than K10D
4fps
And AF is available in Live View which is better than 40D(can't use AF in Live View)
01-10-2008, 10:59 PM   #3
documentation????
01-10-2008, 11:09 PM   #4
and
QuoteOriginally posted by BrendanPK Quote
documentation????
He has a solid source right here, from someone he trusts, himself :
K20D is more of a widescreen format. uhh...Why? + MORE SPECS.: Pentax SLR Talk Forum: Digital Photography Review
1080p, full HD, is this a TV or a camera
full HD is, in terms of camera resolution, very little, should be around 3 megapixels, give or take. Not very impressive
01-10-2008, 11:11 PM   #5
documentation????
The usual. Press release leak.
01-10-2008, 11:12 PM   #6
QuoteOriginally posted by and Quote
LOL.. Yeah, I cross posted it...
01-10-2008, 11:15 PM   #7
and
QuoteOriginally posted by mutley Quote
If you put a bit more effort into it, it would come out a bit more believable I could manufacture a much more realistic rumor than that. Actually if everything you wrote was true, I wouldnt want the new camera at all. EVF like samsung 815 instead of an optical VF ? they would be bankrupt by 2009....
01-10-2008, 11:16 PM   #8
The difference is that it is combined with the optical viewfinder.
01-10-2008, 11:20 PM   #9
Hull HD is 19201080, it makes 2.1 megapixels
01-10-2008, 11:29 PM   #10
If this is all true... this would be a tsunami hitting the DSLR market.. not mere waves.
01-10-2008, 11:31 PM   #11
Well 1080p is a video/TV term and means progressive video stream with 19201080 resolution. Could be 60, could be less frames per second. Above rumours simply doesn't really "stick" together especially where D300 and 1D Mark III are mentioned.
However if those rumours are partially true and have substantial base, then probably it should mean that GX-20 and K10D can film HD videos... Sensor is wide because HD video is 16:9 aspect ratio.
Still hard to believe it's true.
01-10-2008, 11:36 PM   #12
and
QuoteOriginally posted by Edvinas Quote
Well the ISO performance should blow everything else out of the water then
But I am even more shocked to learn the Nikon D3 only does 510p in 11fps mode, 720p is, around 1 megapixel? so less than 1 megapixel resolution, well no wonder they can go beyond iso 6400...
01-10-2008, 11:45 PM   #13
ogl
ogl's Avatar
EVF + OVF + double system of AF in LV are could be true.
In 3:2 ratio we could have 24*16 mm sensor, a bit larger than there are now for APS-C.
01-10-2008, 11:51 PM   #14
ogl
ogl's Avatar
Maybe he means that D3 can shoot in DX mode 2784 x 1848 [L; 5.1 MP] with 11 fps.
And K20D can shoot in 10 Mp RAW mode and 14 Mp RAW mode?
01-11-2008, 01:26 AM   #15
blende8's Avatar
APS-H??????
What a bu||sh|t!
This makes no sense at all.
If these features are true, this really drives me away from this "camera", ehh, multimedia toy.
I will look at it, but will probably wait for the next serious camera.
Well, well, this is the predicted paradigm change, probably ...
af, d300, k20d, live, method, mode, pentax news, pentax rumors, samsung, sensor, view
more dubai shots k20D schufosi777 Pentax News and Rumors 3 06-29-2014 05:40 AM
Highlighting Features - K-7 & K20D On Pentax (JP) Website Thorolf Pentax DSLR Discussion 3 01-05-2010 10:07 PM
Features you may not know about in the K20D imadethis Pentax DSLR Discussion 0 04-04-2008 02:52 PM
K20D features you like HawaiianOnline Pentax News and Rumors 1 03-03-2008 12:12 AM
How many of the K20D features can/will be implemented in a new firmware for K10D? cateto Pentax News and Rumors 6 01-24-2008 01:58 PM
All times are GMT -7. The time now is 05:03 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
