05-19-2012, 06:25 PM   #616
Blue's Avatar
QuoteOriginally posted by HawaiianOnline Quote
I wonder if it will be able to use the higher speeds of UHS-1 cards, something the K5 can't do. It would sure make things go faster if it could clear its buffer faster. Also, I have to wonder if it will have the same bit depth as the K5.
The K30 burst is predicted to be 4 FPS and the K-01 is at 6 FPS with 12 bit. This will be an interesting specification to see.
05-19-2012, 06:39 PM   #617
Certain Forum mods have suggested/implied/speculated/hinted that the 4 fps spec is incorrect/misleading/unsubstantiated/mis-typed/whatever. The correct number, according to a usually-reliable source is 6 fps.
I know full well that this is all fuzzy, Blue, and I'm watching it as well. "Retro" is all in fashion but four frames per second is a bit too retro for me, too ....
05-19-2012, 07:35 PM   #618
It looks like a DA 18-55mm WR to me and it says it is bundled with such and has it mounted in the pic.
Oh, ok then, point rescinded, I only saw the initial fuzzy cap, and couldn't make out the blue 'WR' well, although the UK Amazon caps make no mention of the WR lens.
If it hits the US at $800, with the WR lens, then it's a decent deal.
05-19-2012, 08:56 PM   #619
Yes that scanned WR bundle is for France only thus far, where it is illegal to say something is "tropicalized" but require another purchase. The listed UK bundles were clearly not WR.
05-19-2012, 09:00 PM   #620
lurchlarson's Avatar
Looks good to me. If this is the Kr replacement I can't wait to see the k5 replacement!
05-19-2012, 09:19 PM   #621
Anvh's Avatar
QuoteOriginally posted by karlito Quote
was telling the guy that the a57 is better than a37...i did not buy the sony a57/a37 because it is not waterproof....would have bought the a77 but the jpeg's have a artefacting in them.... so considering the k30, but only if the videoformat is avchd, and it has a flip out screen!!! my fingers are crossed
I certainly hope they won't use AVCHD with 28 Mbit/s limit.... why would you want that even?
05-20-2012, 12:36 AM   #622
4 fps is plenty for this level of camera... imo
05-20-2012, 12:50 AM   #623
TenZ.NL's Avatar
QuoteOriginally posted by WerTicus Quote
Maybe, but the K-r is allready faster with 6fps. This is a midlevel camera, positioned between K-5 and K-r, right?
So why make it even slower then the K-7?
05-20-2012, 01:18 AM   #624
french_mike's Avatar
4 f/s in RAW fair enough, but not in JPEG ...
05-20-2012, 04:56 AM   #625
starbase218's Avatar
Location: Planet Earth, Sol system, Milky Way galaxy, Universe
QuoteOriginally posted by TenZ.NL Quote
Bear in mind that the K-r had to pump out "only" 12x6 = 72MP per second, whereas the K-30 supposedly pumps out 16x4 = 64MP per second. Still not the same bandwidth, but much closer.
Anyway, I think this is mostly a minor issue when you consider the target audience of the K-30.
05-20-2012, 05:03 AM   #626
TenZ.NL's Avatar
QuoteOriginally posted by starbase218 Quote
That is true and I`m no target
PS: Alles goed?
05-20-2012, 05:37 AM   #627
VisualDarkness's Avatar
It looks really good when sprayed by water. They should use this pic for marketing, they should get a similar for K-5.
Ogün Ça?layan Türkay'?n PENTAX Blogu…
05-20-2012, 06:29 AM   #628
aekn's Avatar
Great image, VD, the first I've seen of a "full frontal" K30, too!
05-20-2012, 06:40 AM   #629
QuoteOriginally posted by aekn Quote
Thats surprising... The exact same picture was posted a couple of pages back... By the guy who's name appears at the bottom of it.
05-20-2012, 06:46 AM   #630
mickey's Avatar
A sensual picture that, exhibiting that just-out-of-the-shower look.
camera, dslr, k-30, k30, pentax, pentax news, pentax rumors, picture
Is there a list of Pentax and aftermarket weather sealed lenses? VoiceOfReason Pentax SLR Lens Discussion 15 08-10-2018 10:47 PM
Suggestion Adding categories to Pentax DSLR Discussion Ivan Glisin Site Suggestions and Help 2 01-04-2011 09:51 AM
No discussion of the latest Wikileaks leak? Really? deadwolfbones General Talk 7 07-28-2010 09:30 PM
Pentax Weather Sealed Flash! HermanLee Pentax News and Rumors 16 05-07-2009 08:06 PM
Weather sealed non-Pentax* lenses Spex Pentax SLR Lens Discussion 7 08-29-2008 10:29 AM
All times are GMT -7. The time now is 12:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
