07-19-2012, 06:46 PM   #61
Edgar_in_Indy's Avatar
QuoteOriginally posted by Kona Quote
Nobody has answered my earlier question as to what exactly is wrong with plastic mounts. I really don't get it, and somebody needs to explain the hate.
The biggest disadvantage is that they don't look as cool. They also may not make as satisfying a 'click' as metal mounts when snapping the lens into place. But on the upside, they won't cause surface scratches on your camera's lens mount.
On a large or heavy lens (like a 70-200mm f/2.8 or a 'Bigma') that puts a lot of force on the mount when the lens is hanging in space, I expect that a metal mount may offer some structural advantage, but for a small/light lens it's probably not an issue.
07-19-2012, 07:19 PM   #62
They break. Also plastic mounts don't have the ability to manual focus when the camera is set to AF.S or AF.C - you have to actually switch the camera to MF to turn the focus ring. They are generally all-around of poorer construction than metal mounts, although the same optics.
07-19-2012, 07:32 PM   #63
QuoteOriginally posted by ENicolas Quote
Umm...I don't think that actually has anything to do with the material the mount is made from.
07-19-2012, 07:59 PM   #64
Docrwm's Avatar
Wow. First, its the quick shift that allows the focusing when not in MF on the camera and that is at the other end of the lens.
Second, just where are the reports of the plastic lens mounts used in modern Pentax lenses breaking?
Third, all-around poorer construction? Really, and just what is the failure rate of the DAL 18-55, DAL 50-200, DAL 55-300, and the DA35/2.4? Now, take those numbers and compare them to metal mounted highest priced lenses offered by Pentax, oh say the SDM Zooms. Now, which has the higher failure rate? Which are more poorly constructed?
Wow.
07-19-2012, 08:04 PM   #65
Ash
Community Manager
Ash's Avatar
QuoteOriginally posted by Docrwm Quote
I certainly am hoping you are right! If the 35/2.4 were all metal with the same optics (which are what really matter) people would rave about it. I'd love to see them do an 18mm like the 35 too.
A metal build is available now: 35 ltd
As for DAL lenses breaking: yeah, if they're dropped a few times, from a >3m height or so, sure, they would before metal mount lenses do, but I wouldn't expect that most people are into extreme photography in austere conditions where such durability is a must...
07-19-2012, 08:08 PM   #66
Docrwm's Avatar
A metal build is available now: 35 ltd .
Oh, right, the SLOWER version of the lens.
07-19-2012, 08:10 PM   #67
Ash
Community Manager
Ash's Avatar
Slower by about half a stop... little to worry about there. The 35 ltd is also a macro, though.
07-19-2012, 08:12 PM   #68
Docrwm's Avatar
Slower but Macro, seems a wash to me - so it sells for about the same as the 35/2.4 - right?
07-19-2012, 08:21 PM   #69
Ash
Community Manager
Ash's Avatar
Clearly not, but also clearly it is built like a tank with awesome IQ and is a lens to last forever like the other Limiteds...
That's how I like to see lenses anyway...
07-19-2012, 08:22 PM   #70
Wow. First, its the quick shift that allows the focusing when not in MF on the camera and that is at the other end of the lens. Second, just where are the reports of the plastic lens mounts used in modern Pentax lenses breaking? Third, all-around poorer construction? Really, and just what is the failure rate of the DAL 18-55, DAL 50-200, DAL 55-300, and the DA35/2.4? Now, take those numbers and compare them to metal mounted highest priced lenses offered by Pentax, oh say the SDM Zooms. Now, which has the higher failure rate? Which are more poorly constructed? Wow.
Well, I have to admit I don't own them all - in fact I don't own any plastic mount lenses. I'm just going by forum posts I've read, product reviews, and as far as quick-shift goes, Pentax's own product descriptions. Breakage may not be a huge problem with this short lens, but it definitely is with the 55-300mm DA-L zoom - you can read about that in user reviews on Amazon and other sites.
Sorry I don't have any rigorous statistics to share - I tend to just go by what I read, what other people say, etc. - you know, the same stuff most people go by in day-to-day real life.
07-19-2012, 08:22 PM   #71
Plastic would break, metal would dent, but in reality if either lens was impacted hard enough to break/dent, then it's not going to be good for the lens.
07-19-2012, 08:23 PM   #72
QuoteOriginally posted by Edgar_in_Indy Quote
Nope - just seems to be what Pentax does with them going by their own product descriptions and reviews.
07-19-2012, 08:31 PM   #73
Ash
Community Manager
Ash's Avatar
You know that what you read on fora like this doesn't accurately reflect the reality. You'll always get selection bias and have users who report failures actively posting to say how their gear failed. This will happen whether the gear was misused, abused, or otherwise. The plastic mounts are fine. The DAL lenses are so much lighter you might think that they're prone to failures or are cheaper in optical quality, but Pentax are known to make good gear that is small, light as well as durable and optically brilliant. FA and DA limiteds are testament to this.
07-19-2012, 08:35 PM   #74
JinDesu's Avatar
Plastic mount breaks, hah.
My friend dropped my k-x with the DA 35 F2.4 from above head height (i.e. about 6') to a marble floor. Both are fine.
If he didn't look so sorry, the most damaged thing in that room would have been him, but alas, since the camera and lens were fine...
07-19-2012, 10:28 PM   #75
I agree to this!
QuoteOriginally posted by JinDesu Quote
If I fell (and landed flat, not with my feet) from that height, I would've had a few broken bones.
Plastic K-x and plastic mount lens= tougher than my own body... or in that case at least Sure it's plastic, but it's not as brittle as some may think.
but in any case, accidents happen, and one does not simply drop his lenses anyway, so if it makes the photography experience easier (weight issues, how long can I handle my K-x with the DA 35 f2.4? Hours on end!) I guess it's fine.
50mm, 50mm f1.8 lens, da, da 50mm f1.8, f1.8, lens, pentax, pentax da 50mm, pentax news, pentax rumors, ships
Sigma 17-50mm f/2.8 for Pentax - $549.99 at Amazon.com ahw Pentax Price Watch 9 02-28-2012 03:32 PM
Amazon 1 day lens sale - No Pentax Mounts interested_observer Pentax SLR Lens Discussion 7 12-21-2011 03:15 PM
For Sale - Sold: RARE PENTAX LENS k 28MM F2, k 50MM F1.2 FA 35MM F2, FA 50MM Macro, Pouc (Worl rajubhai55 Sold Items 11 06-21-2011 03:27 PM
FA 50mm F1.4 $699 on Amazon..What the Crud?? 68wSteve Pentax SLR Lens Discussion 16 08-30-2009 04:52 PM
FA 50mm f/1.4, down to $169.99 via Amazon deadwolfbones Pentax SLR Lens Discussion 15 02-06-2009 12:12 PM
All times are GMT -7. The time now is 09:05 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
