Please take note that this is posted through translation(Japanese to English) and so keep in mind that the message may be significant different from what is intended:
Originally posted by http://digicame-info.com: We have to provide information such as image, price and release date of Pentax K-5 IIs and K-5 II from readers.
(On-sale date) is scheduled for mid-October launch of the K-5 IIs and Pentax K-5 II
Around 110 000 yen, over-the-counter expected price is K-5 II K-5 IIs are around ¥ 120 000
Suggested product images: upated images... Originally posted by photorumors.com: The Pentax K-5 II and K-5 IIs are slated to replace the now older K-5 model. The replacement models are expected to hit stores by mid-October. The price is rumored to be around $1,400 for the K5 II and $1,500 USD for the K5 II/s respectively.
Here is a complete list of features and specifications for the Pentax K-5 II / K-5 of IIs DSLR camera (Google translation):
- APS-C CMOS sensor 16.28 million effective pixel sensor (1.5x)
- Newly developed SAFOX X AF module
- Supports up to ~ +18 EV-3EV is AF. High accuracy corresponding to the luminous flux of F2.8
- Expansion function select area to continue tracking even if the subject deviates from the selected AF point
- Gapless 3.0 inch LCD monitor screen with 921 000 dot LCD
- PRIME II image processing engine
- ISO range is ISO80-51200 with expansion
- Magnesium Alloy frame with chassis water resistant body
- 30-1/8000 with 100 000 shutter life
- 100% field of view with 0.92x magnification pentaprism viewfinder
- 7 frames per seconds continuous shooting, 20 frames in RAW
- Video - Full HD (1920x1080, 25fps), HD (1280x720, 30/25fps)
- Video file format Motion JPEG (AVI)
- Three phase image stabilization in the body. (automatic, horizontal correction, composition adjust)
- Custom image nine
- Multi-segment metering 77
- Electronic Level
- With DR II dust removal function
- The media SD, SDHC, SDXC
- Size: 131mm x 97mm x 72.5mm
- Weight (body only), 760 g (battery, included media) 680g
- In the low-pass filter-less (only K-5 IIs), to maximize the performance of the sensor
Read more on PhotoRumors.com:
Pentax K-5 II / K-5 IIs specifications | Photo Rumors older images... (lower resolution) Originally posted by http://digicame-info.com: It is the information from people you trust. The appearance of the K-5 II, it is almost the same except for the K-5 logo. Spec is unknown at the moment, what the low-pass-less version of K-5 II is K-5 IIs?
It seems slightly cheaper price than the opening price of the K-5. In addition, three of the top in the K-5 II, the image on the back of the image with the top surface of the (K-5 IIs the bottom one is the K-5 IIs are exactly the same, so omit K-5 II was).
Source: http://digicame-info.com
