09-13-2012, 04:00 PM   #76
QuoteOriginally posted by Clinton Quote
Oh yawn. So much debate over so little.
How many times in the last week have you complained about people complaining on the internet?
09-13-2012, 05:44 PM   #77
Docrwm's Avatar
QuoteOriginally posted by ElJamoquio Quote
How many complaint threads has he started
09-13-2012, 08:15 PM   #78
Clinton's Avatar
QuoteOriginally posted by Docrwm Quote
Apparently at least one that suckered you into looking at it
I'm not complaining.... much.
09-14-2012, 06:52 AM   #79
Blue's Avatar
And the DA560 seems to have SMC in the ads but some say the lens is marked HD. Just chaos IMHO.
Pentax Imaging did get HD on the DA 560 though. It doesn't mean they got it right on the super zoom either. They screwed up on the DA 35/2.4 AL when it came out calling it a DA-L 35/2.4.
09-14-2012, 07:06 AM   #80
QuoteOriginally posted by dadipentak Quote
huh? It makes no sense: How do you get the acronym "hd" from aero bright"?
09-14-2012, 07:20 AM   #81
Blue's Avatar
Huh? It makes no sense: how do you get the acronym "HD" from Aero Bright"?
AS it turns out, it isn't Aero Bright, its "not quite as good as Aero Bright" as per Pentax.
09-16-2012, 08:05 AM   #82
RuiC's Avatar
QuoteOriginally posted by RobA_Oz Quote
In the Press Release for the DA 645 25mm, Aero Bright is described thus:
The key to this possibly lies in the reference to nanotechnology. Nano coatings are referred to in this article: What does a 'nano crystal coat' do on this lens? - Photography, which details the difference between multi-coating and nanocoating, even though the specific lens referred to was a Nikon one.
Don't know about ghostless coating, although from the name that could apply to either multi or nano-coating. On the surface of it (no pun intended) the acronym "HD" is, I agree, an undistinguished term to apply to a lens coating, unless it stands for something that none of us has seriously worked out, yet.
Aero Bright is described here:
United States Patent: 8199404
and HD is described here:
United States Patent: 8231966
09-16-2012, 06:02 PM   #83
Blue's Avatar
QuoteOriginally posted by RuiC Quote
The first one looks more like the SMC Coating and the second one Aero Bright
09-17-2012, 03:18 AM   #84
RuiC's Avatar
Yes it may look like, but this one was filed in 2008 while SMC is much, much older, I believe.
09-17-2012, 04:02 AM   #85
Docrwm's Avatar
The term "SMC" is much older, true. However, Pentax has had to file new patients for "SMC" every few years because of updates to the process.
09-17-2012, 06:16 AM   #86
Blue's Avatar
As Docrwm pointed out, they have updated the formula and patent several times since the release of the first S-M-C Tak. Plus, that first one doesn't seem to be a nano technology.
09-17-2012, 09:16 AM   #87
RuiC's Avatar
OK !! It doesn't seem to be a nano technology:
" ... the first layer 11 has an optical thickness of 37.5-112.5 nm,
the second layer 12 has a refractive index of 1.95-2.25 and an optical thickness of 35.5-60.0 nm,
the third layer 13 has a refractive index of 1.35-1.50 and an optical thickness of 24.5-41.5 nm,
the fourth layer 14 has a refractive index of 1.95-2.25 and an optical thickness of 210.5-250.0 nm,
the fifth layer 15 has a refractive index of 1.35-1.50 and an optical thickness of 12.5-32.5 nm,
the sixth layer 16 has a refractive index of 1.95-2.25 and an optical thickness of 27.5-45.0 nm, and
the seventh layer 17 has an optical thickness of 108.0-138.0 nm,
wherein the optical thickness=refractive index.times.physical thickness.
"... The organically modified silica preferably has a particle size of 200 nm or less in the dispersion. ..."
09-17-2012, 05:56 PM   #88
HD now means Aero Bright. who thought of that?
f2.8, hd, ii, information, k-5, lens, macro, pentax, pentax news, pentax rumors, smc, telephoto
Replacement for SMC Pentax 300mm F4 Sudhakar Pentax SLR Lens Discussion 18 03-14-2012 09:48 AM
Will there be a K-R replacement soon? redogman67 Pentax DSLR Discussion 15 09-25-2011 09:39 AM
Replacement lens cap for SMC-A 1:2 50mm roflzzhaveridges Pentax SLR Lens Discussion 3 05-01-2011 02:01 AM
Replacement K-5. Mike.P Pentax K-5 36 04-03-2011 11:18 AM
Replacement for Pentax SMC DA 18-250mm 3,5-6,3 ED AL 18-250 mm ?? Ivo_Spohr Pentax News and Rumors 14 04-26-2010 10:15 AM
All times are GMT -7. The time now is 04:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
