Originally posted by Class A I don't believe that to be true.
SONY has in-body stabilization with their FF models as well. There isn't much safety margin required and typical lens designs have no problem of delivering.
If I am not mistaken the K-mount inside diameter is 45mm which is 1mm smaller than NEX E-mount and one millimeter larger than the Nikon F-mount. I don't know the exact size of the A-Mount used on the A99, but it is noticeably larger than the E-mount which is bigger than K-mount. Sony has more room. Pentax and Nikon were both designed in the film era to be as small as possible. I don't think there is room for any significant movement of a FF sensor in either a Pentax or a Nikon body. Canon has the largest with the EF mount being 54mm but since it has a shorter register distance it needs a wider mount. Sony has the second largest and its register distance is only 1mm shorter than Pentax.
A 24x36mm sensor would require an image circle of more than 43.3mm without SR. With SR how much more room do you need?
What exactly is the specification of the image circle projected by a K-mount lens?
The mount is designed to provide the smallest most compact bodies and lenses on the market. I don't think there is room.
I would be surprised it Pentax went to the expense of designing OIS for 645 and we did not see it on K-mount. They need to spread out R&D costs across as many products as possible.
