11-04-2012, 11:57 AM   #166
Blue's Avatar
I have to say Blue, that's the one thing that would get me back into film would be the chance to shoot with a 4x5 view camera. There's a place in Toronto that would process my film, so it would be doable. The digital scanning back for said camera is $17,000 and takes 300 MP files. If there's one thing I hate about digital it's the lack of large sensors. And that's not a minor complaint. That's major. But I also don't have 17 grand to blow on a scanning back, and scanning backs take very long exposures 52 seconds to 15000 seconds depending on exposure. For landscapes, your light could change while you're taking the picture. People talk about having more control with FF have obviously never used a view camera with tilting rotating fronts and backs. Now that's control.
95% of my work related stuff is with digital and have to honestly say that I do the film stuff mostly for fun.
11-04-2012, 12:34 PM   #167
gazonk's Avatar
2) there isn't a 6 x 7 digital in my price range and certainly not a large format
Pentax is doomed if they don't bring out a 67D this year!
Seriously, a 6x7 would probably make more sense as a mirrorless camera, wouldn't it? (to avoid mirror shake and keep size down)
11-04-2012, 12:49 PM   #168
thibs's Avatar
QuoteOriginally posted by gazonk Quote
And abandon the magnificent viewfinder you'd get with a mirror ?
Not for me. But I wouldn't ditch the idea as being silly. Just not my take on things.
11-04-2012, 12:54 PM   #169
thibs's Avatar
Same here. I do digital because I must and is convenient. I do film because that's how I really enjoy photography. Even though film comes with its own burden. A pity a good film scanner (MF or 4x5) is hugely priced &
Canon 9000F is said to be quite OK with 4x5... I still fancy darkroom. Even though it takes many more hours than digital. It's just not the same things.
11-04-2012, 12:56 PM   #170
gazonk's Avatar
QuoteOriginally posted by thibs Quote
If I had the money to buy a 645D, I'd certainly want it with a mirror. But the 67 is more prone to mirror shake, isn't it?
11-04-2012, 12:57 PM   #171
normhead's Avatar
OK then imaging this.. a 6x7 sensor as a view camera with an iPad size screen on the back with retina display for the viewfinder, used as in live view. Rotating and tilting front and back both of which can be raised and lowered, and 100 to 150 Mp output. To me, that would be a camera worth looking into.
11-04-2012, 01:01 PM   #172
thibs's Avatar
QuoteOriginally posted by blacknosugar Quote
Exposure latitude and dynamic range are not the same thing.
Digital actually has a pretty narrow slide-like latitude.
Mmm I'm not sure about that but I'm willing to get more about the issue.
IMO, it's pretty comparable, if not the same.
As for narrow slide-like latitude, I think this is a thing of the past.
Sensor as the K5's sensor really are marvels.
I dunno if the digital is better, but digital isn't anymore near slide.
11-04-2012, 01:04 PM   #173
Blue's Avatar
Not if you have mirror lock up.
11-05-2012, 12:23 AM   #174
David's Avatar
Now if they could only add darkroom smells to digital cameras that would help. I have a trailer load of 6x7 Mamiya and darkroom gear just rotting away.
David
11-11-2012, 02:32 AM   #175
aurele's Avatar
In that case, be ready to let go many many grand
11-11-2012, 03:53 AM   #176
RonHendriks1966's Avatar
iPad mini would be already great, but I do get the concept. Large sensils, like in D600 would only give 108 megapixel. Probably that would be more then enough to work with.
Should a camera like that not have AF? Mirrorless probably would be a very goos solution.
11-11-2012, 08:32 AM   #177
normhead's Avatar
If you have a dio
QuoteOriginally posted by RonHendriks1966 Quote
The whole point of a camera like that is to be able to align your film plane with your subject and to have complete control over the angle of the focal plane. I'm not sure you can ever completely automate that. But cameras even now have trouble deciding in 2D what should be in focus. Add front and back elevation and lift and rotation to the process and I'm not sure you could even write a algorithm that could process that. I guess if you have one of those monster computers IBM taught to play chess, and a very good team of programmers. But it's unlikely it would ever be completely auto-fucus. You would have to have some way of telling the computer what you want it to do. Like selecting 3 points you want in focus in an image and telling the computer to do the math. But another advantage to tilt is aligning the film plane for capturing vertical faces in landscape and for keeping building lines parallel in acrhcitecture. If you look at camera equipment, fixed front and back parallel to each other is a very simple system. If you look at the possibilities of a view camera, only a very small percentage of landscape and architectural shots taken with DSLRs or even SLRs would be taken the way they are, if you were using a view camera. You really have no idea how much more flexibility you have with a view camera if you haven't used one. You also have no idea how much time you can waste trying to get the perfect picture, while learning to use one.
Or the short answer is, view cameras are the epitome of mirrorless
Look at how this camera is cranked. The lens is not parallel on (either axis)to the film plane, the lens is elevated and whatever this guy is taking a picture of, you cannot emulate that shot on fixed plane cameras.
It makes me incredulous when people talking about having more control with an FF. You get next to no control with fixed film and focal plane systems. Whichever one you choose.
WIkipedia's explanation.
My latest plan is Canon 6d with a tilt lens and an tablet computer for focus peaking connected by USB. Many thousands, but doable, as opposed to a view camera with a scanning back, which as far as I can tell is just way out of my range and too long an exposure time to be functional much of the time, even for landscapes.. But that wouldn't give me the monster resolution a view camera is capable of.
11-11-2012, 09:19 AM   #178
If you have a dio
and lensbaby isn't enough I guess (but it is the same principkle I think).
11-11-2012, 10:01 AM   #179
normhead's Avatar
I haven't really spent a lot of time investigating the DSLR options because the viewfinder has to big enough to allow your evaluate your image. WIth something like an camera tethered to iPad, I think you might be getting there. The other issue is on small sensors you really need good lenses. Every tilt front for an APS-c or FF I've seen you have to use the lens that comes with it. A true view camera can use different lenses just like an SLR. It's hard to get excited about investing in a system, that only gives you one focal length. ALso it doesn raise and lower, but in the absence of laying out 20 k for a real camera, I should probably have one. How do you know what your lens quality is going to be? It's not like you can put any lens you want on that? Rotate and tilt, but no elevate. But you still need a bigger view screen.
11-11-2012, 01:17 PM   #180
thibs's Avatar
I
+1 Excellent post. I'd quote all of it but that shouldn't be done
645d, ff, image, iq, lens, line-up, pentax, pentax news, pentax rumors, segment, sensor, slr
Translation of Kitazawa Interview v5planet Pentax News and Rumors 364 12-25-2012 06:32 PM
Mr. Kitazawa slated to announce Pentax upcoming bodies in Dec 19'th JohnBee Pentax News and Rumors 429 01-02-2012 09:57 AM
Head to head shoot out Pentax 645D vs. Canon 1Ds Mark III Mystic Pentax News and Rumors 26 11-04-2011 04:36 PM
Black & White Stark Winter Branches - Watch Your Head Sailor Post Your Photos! 9 01-04-2011 05:51 PM
Interview w/ Pentax Head of Marketing - NEEDS TRANSLATION illdefined Pentax News and Rumors 17 09-29-2010 02:13 AM
All times are GMT -7. The time now is 04:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
