Originally posted by twinda1 Also: what I never understand about the ISO numbers is are those numbers the best possible? For instance, if I shot RAW, is there an optimal workflow that gets me better high-ISO performance if I were willing to work at it?
Well, actually I think there is. But I also think any converters need some tweaking before they get most out of the new sensor, and as I do not have that I actually haven't tried it. In stead I've used jpegs only.
Everybody is paying a lot of attention to the Pop photo test. But several pictures with noise reduction on and off and with firmware 1.0 were available on the net before te pop photo test to help you judge for yourself.
Personally, I tend to believe the pop photo noise results for the time being, despite the fact that it's not clear if NR was on or off ( though the low iso 800 value may indicate NR kicking in). Noise levels without NR are higher than the d300 at least, but the noise is very very fine. Combined with the high resolution even at iso 6400 I have been able to PP the jpegs to produce very clean pictures with vbery good detail. Thus,despite showing the verdict' uneacceptable' in pop photo, I tend to say 'don't judge it until you've tried yourself'.
Actually, PP D300 pictures (with NR on btw) did not give me much different results. PP the A700 pictures (with NR on btw) never gave me the same quality sofar because of the patchy color reproduction at high iso.
So I suggest we all wait until we get our hands on a decent K20d with firmware 1.0, and see what happens if NR is on or off, throughout the entire iso range, and how these pictures respond to PP.
I personally would have rated pop photo's testing much higher if they would have actually found that 'high speed AF-function' and tested it properly. That would have been news to me. But I guess they really never looked for it. That actually tells me more about how they test cameras than anything thet produce from a standardized measurement (however small the samples may be).
This is iso 6400 on the k20d (thanks to Blende8 who gave us the original jpeg without NR), but after light PP with Neat Image:
I can live with this, because I'm used to the k10d high iso performance after NR.....
lock
