Originally posted by eurostar
And that how should be different from AF-S?
If you take a bunch of photos by holding the shutter down w/ AF-S, I think it only locks once and then takes the next set of pictures w/ the focus locked in the same spot. AF-C should keep locking before each photo depending on what is under the focus point indicator that is chosen.
There is also an option for AF-S mode to turn off the double check (not the same as trap focus mode in AF-C). This should speed up the apparent AF time at the expense of focus accuracy.
Again, this is how I understand the new options to work. Maybe Codiac or someone who has actually played w/ the K20D can confirm...
