12-21-2012, 08:38 AM   #121
ogl
ogl's Avatar
QuoteOriginally posted by Clavius Quote
Exactly, if the K-mount is ditched, then users can just as wel switch to Canikon.
If Pentax is going to be exactly like Canon or Nikon... Then what's the use of buying a Pentax?
It's a good move if you want kill Pentax off though.
I don't see any logic in your words...How could it be?
Pentax has just several 35 mm lenses. 95% of lenses are for APS-C.
12-21-2012, 08:41 AM   #122
ogl
ogl's Avatar
creampuff:
And I 100% disagree. No offense, but every point you made is not valid.
- lenses with improved SDM/DC, FF image circle, new optical construction and new lens coatings can very well be K-mount.
- you're ignoring the users with new lenses, ready to spend more into the K-mount, on both lenses and cameras. They are those who give money to Pentax.
What do you mean? Old users with new lenses? New lenses are for APC-S.
No any connection between DA lenses for APS-C and new FF lenses.
12-21-2012, 08:44 AM   #123
Blue's Avatar
QuoteOriginally posted by ogl Quote
Nikon uses a "crop mode" for this issue. Nikon has aps-c lenses and ff lenses with the F mount which has been around since 1959.
12-21-2012, 08:47 AM   #124
gazonk's Avatar
Several of the DA lenses can be used with less crop than 1.5x, so a crop individually tailored for each lens would be cool.
12-21-2012, 08:48 AM   #125
ogl
ogl's Avatar
Nikon uses - it's Nikon's move. No any sense in crop-mode. Why must Pentax be Nikon???
12-21-2012, 08:48 AM   #126
Reading the very last part of the article, I got the impression that they are at least toying with the idea of ditching the K mount for the upcoming FF (if they come at all). This probably means that they have at least created a mock up or two with a new mount. Either way, they will ensure that old K mount lenses will be compatible with adapters of some sort. I also suspect that if they use a new mount, this will be compatible with, and can be optimized for mirrorless FF (for the corner sharpness he says) if they ever decided to go that rout. As Ogl suggested, I think the money is at the lenses and adapters, and this is so very true.
12-21-2012, 08:49 AM   #127
A modern electronic mount has a lot of advantages, and would probably increase third-party lens support as well, which has been dwindling. If they can come up with an adapter that allows full-feature (or crippled as we have become used to) from K-mount (and release it at the same time as new system), why not?
There's nothing stopping K-mount from becoming a "modern electronic mount." Remember, it started off as just a bayonet with a mechanical aperture coupler.
Then an analog contact was added. Then digital contacts. Then power zoom contacts. Then SDM.
Whatever modernization is really necessary can be added, short of (a) lenses faster than f/1.2, and (b) decreased register distance. On an FF camera I wouldn't really want either of those things.
Just add contacts, or dynamically redefine the ones that are already there based on the kind of lens attached, like is already done for analog vs. digital lenses.
12-21-2012, 08:49 AM   #128
ogl:
If you can't find the logic, it doesn't mean there is none; just that you couldn't find it. Maybe you didn't even search...
Clavius is right; if the current K-mount users would have to change the system anyway in order to go FF, why not jump to Canikon?
If the current K-mount users would see their system being phased out, why not jump to a more viable system, e.g. Canikon?
If one wants a dual APS-C + FF kit, and Pentax would have two separate mounts for that, why not go to a system which is more convenient, e.g. Canikon?
And so what if they have just several 35mm lenses? That's already much better than none, than starting from scratch. Do they need more lenses, yes, they do - but those can be K-mount.
Yes, "old" users with new lenses, i.e. the current K-mount user base, the people on which Pentax survives. Are they irrelevant to you?
12-21-2012, 08:50 AM   #129
ogl
ogl's Avatar
Pentax FF will have new mount. And it's FULL STOP...
12-21-2012, 08:51 AM   #130
The patents for the 60-250 and the 300 call them out as FF. The 300mm certainly is FF. I'd be shocked if the 560 isn't.
Pentax has about 10 FF lenses, so about 20-30% of their lenses are in reality FF.
12-21-2012, 08:52 AM   #131
gazonk's Avatar
QuoteOriginally posted by Franky2step Quote
Pentax is already losing the battle for full frame
No, there's still room there. The Canon 5d/6d cameras IMHO are quite boring and with a rather mediocre (for its size) sensor. The only really terrific FF camera right now is the D800, but it's not for everyone - for instance it's quite bulky.
If Pentax brings a WRed, sturdy and compact camera with some unique features to the market, I think it's plenty of room for it. After all, the FF market is still in its infancy and very small compared to the APS-C market.
12-21-2012, 08:53 AM   #132
Don't make up things, and present them as a fact.
12-21-2012, 08:54 AM   #133
ogl
ogl's Avatar
QuoteOriginally posted by ElJamoquio Quote
Alas...60-250 is not FF at all. We don't know how DA* lenses (not officially FF) will work at high MP FF camera. Pentax already knows...
I think it won't be perfect.
Canon remake new line of FF lenses for high resolution FF cameras. Pay attention!!! Sony and Nikon do the same...
The next FF sensors will be 32, 36 and 46 MP. APS-C will be 24 MP.
Old K-mount lenses from film era are already so-so at 16 MP APS-C. Not all, but a lot of.
12-21-2012, 08:55 AM   #134
Blue's Avatar
Its not about becoming Nikon. Its about staying Pentax. I used them as an example because #1) they started out in the slr business with the F mount and still use it; and 2) it has similar dimensions including registration distance to the K-mount. Changing mounts for the sake of changing mounts would be a silly move for Pentax given the K-mount is their bread and butter at present. Likewise, it would be dumb for Nikon to make a switch. Canon got away with it because they did it in the 80s.
12-21-2012, 08:57 AM   #135
ogl
ogl's Avatar
I put smile... It's just provocation Excuse me. But...I really hope for new mount.
interview, pentax, pentax news, pentax rumors, translation
GOLDMAN: The Economic Crisis Ends In 2013 jeffkrol General Talk 4 12-10-2012 03:27 PM
K-30 cash back in Europe November 2012 January 2013 RKKS08 Pentax K-30 & K-50 14 11-17-2012 07:48 AM
New Jersey set to host F1 race in 2013 ! jogiba General Talk 4 10-27-2011 06:37 AM
Who can translate this Japanese Pentax book? Asahiflex Pentax Film SLR Discussion 2 12-28-2010 09:20 AM
Can you see who is hiding in this tree ? sawtooth235 Post Your Photos! 12 02-12-2009 02:06 PM
All times are GMT -7. The time now is 12:14 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
