01-31-2013, 08:21 AM   #16
Lowell Goudge's Avatar
Here's a new firmware version which fixes the DA 560mm's live view AF performance on the K-5, K-5 II, K-5 IIs, K-30, K-01, K-r:
New K-r, K-01, K-30, K-5, and K-5 II/IIs Firmware - Pentax Camera News & Rumors - PentaxForums.com
it would be nice to see if anyone on the forum has the 560mm
01-31-2013, 08:41 AM   #17
gazonk's Avatar
Going to ask them that at our CP+ interview. Pretty sure this firmware does nothing more than fix the CDAF performance for the 560mm though
At least the K-5 download also says "Improved stability for general performance"
01-31-2013, 09:34 AM   #18
ogl
Banned
QuoteOriginally posted by klh Quote
Do you all recalibrate lenses after a firmware upgrade?
No. Everything is the same.
The focus peaking could be added by firmware. It's fact. Why can't Pentax do it in K-5II?
PRIME II or PRIME M (In-camera processor) don't effect on focus peaking mode. It's software fucntion, not hardware.
01-31-2013, 12:19 PM   #19
QuoteOriginally posted by ogl Quote
Yes, it's a software function that's enabled by having sufficient processing capacity in hardware.
If the hardware is not up to the task, then implementing it in software anyway will have adverse effects on other camera operations.
01-31-2013, 12:56 PM   #20
mde1970's Avatar
OK, so just about to upgrade my K5, when I checked the readme it states below text (in bold). Now checking my k5 the current level firmware I have is 1.01.
So I'm a little confused. Can I go ahead and install this update?
Firmware is the software that runs inside digital cameras.
Updatable models
K-5 digital SLR cameras running Firmware Ver. 1.00/1.02/1.03/1.10/1.11/
1.12/1.13.
01-31-2013, 12:59 PM   #21
mde1970's Avatar
Think I may have answered my own question. I cant see v1.00 on Pentax website so assume the Readme should have said 1.01 anyway.
Anyone agree?
01-31-2013, 01:37 PM   #22
The new firmware will completely replace the old one, so go for it. Be sure to have a fully loaded battery, and follow precisely the instructions.
01-31-2013, 02:28 PM   #23
QuoteOriginally posted by mde1970 Quote
Anyone agree?
Yup you'll be fine, go ahead and upgrade.
01-31-2013, 02:30 PM   #24
... except the part precisely about version numbers.
01-31-2013, 07:35 PM   #25
Is it worth it to upgrade the the K-5 IIs to 1.02 now? hmm. Thinking of making a video of most functions first before doing so... or just wait for more reports Hope it fixes the popup flash-hangs-the-cam bug.
QuoteOriginally posted by sarabico Quote
manual video control on the k-5?? i guess we'll never see it... K01 does it, itīs so hard to put it on the k5. Time to abandon ship...
K-5 was designed primarily with the stills photographer in mind, from what it seems. Also, with the mirror mechanism holding back extended video recording as well as other hardware limitations, it can never do video as good as the K-01 (if being videographer is what you mean).
Otherwise, the K-5's video is fine enough for most users.
QuoteOriginally posted by Fandanguero Quote
DSLR cameras as video shooting platform become more and more important.
Which is prolly why Canon's improving the video side so very much. 1D-C, anyone? I'd rather the K-01 (even though it's controls are limited still, but hey, it's the cheapest option to record past 30 minutes without the temperature warning threatening you every now and then)
02-01-2013, 06:35 PM   #26
dickymastelero's Avatar
Downloaded new firmware ver. 1.14 on my Pentax K-5, I did some testing on my 16-50mm f2.8 DA* and 50-135mm f2.8 DA* before and atfter downloading new firmware. There is a big difference in speed of autofocus on this lens and also with other Prime Lens. On DA* lenses the SDM's really focus faster than usual, seems like twice the speed now and you can hear the motor move more audibly. I've did some tethering on my AF adjustment last time and now with a faster AF speed the sharpness is really bang on.
The testing I did is low light night time lampshade lit living room setup, I don't know really how the upgrade affects the kit lenses or other slow lenses but definitely it made a change for fast lenses especially those with SDMs. I hope others will test their fast lenses in this new upgrade and put input in this progress with Pentax. I probably not bother buying a K5-IIs anymore, Thanks Pentax
02-01-2013, 08:29 PM   #27
Kenn100D's Avatar
Check you ISO NR Configuration. It change. There area now a deeper iso range when choosing when NR will kick in.
02-02-2013, 06:34 AM   #28
benjikan's Avatar
QuoteOriginally posted by dickymastelero Quote
Are you serious? I just upgraded to the new firmware but have not yet had the time to test my lenses. Sounds like great news! I hope it isn't just a placebo effect.
02-02-2013, 09:29 AM   #29
QuoteOriginally posted by benjikan Quote
I agree. The AF is my only serious complaint of the K5, everything else is just perfect
02-02-2013, 09:59 AM   #30
mbukal's Avatar
QuoteOriginally posted by dankoBanana Quote
because I have no money to better : O , use the K30 and I have no problems with AF : Cool: , so far I have had and used the Km, Kx, Kr (borrowed for use K5) : Hmm:
firmware, ii, k-01, k-30, k-5, k-r, pentax news, pentax rumors
K-5 K-5 II K-5 IIs, e dial issue, Noise Eder Pentax K-5 & K-5 II 17 06-03-2014 12:33 AM
K-5 II and K-5 IIs Firmware 1.01 Available Adam Pentax K-5 & K-5 II 10 01-18-2013 08:35 AM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 & K-5 II 62 12-22-2012 10:12 PM
K-01 Now or Wait for K-5 IIs or K-30? Biro Pentax K-01 10 11-21-2012 09:31 PM
Suggestion K-5 forum renamed to K-5, K-5 II, and K-5 IIs? Buschmaster Site Suggestions and Help 2 10-16-2012 02:17 PM
All times are GMT -7. The time now is 12:09 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
