02-18-2013, 04:07 AM   #61
QuoteOriginally posted by NeverSatisfied Quote
I've been using the same Pentax AF540, beginning with a K10D up to my current K5II. From what I'd read elsewhere, the overexposure problem was only with Pentax flash. IIRC, people using Metz didn't seem to have the problem.
The issue is the same with Metz flash:
02-18-2013, 09:47 AM   #62
NeverSatisfied's Avatar
Thanks Lage, well I stand corrected then. But I do believe flash exposures are improved now after this new firmware upgrade, at least for the K5II, can't comment on the K5 specifically.
02-18-2013, 10:31 AM   #63
Interval shooting borked?
I'm not sure I've done interval shooting on the K-5 before (but I did on the K-10 or K-20). After the upgrade I tried some interval shooting to capture some cloud movement, planning to compile the frames into video later.
To my surprise the camera didn't interval correctly. Set to 10 second intervals, it would sometimes skip an interval, then shoot two frames in a row. AF is moved to the back button, so it wasn't trying / failing at AF during the run.
Anyone else?
02-18-2013, 02:04 PM   #64
Smeggypants's Avatar
Did some more comparisons between my K-5 that has 1.03 installed and the other one which has 1.14 installed. Absolutely NO DIFFERENCE to AF speed or accuracy on any of my lenses. if anyone is updating to 1.14 from a version earlier then 1.03 then you will of course get the improvements to lower light AF which came with 1.03
firmware, ii, k-01, k-30, k-5, k-r, pentax news, pentax rumors
K-5 K-5 II K-5 IIs, e dial issue, Noise Eder Pentax K-5 17 06-03-2014 12:33 AM
K-5 II and K-5 IIs Firmware 1.01 Available Adam Pentax K-5 10 01-18-2013 08:35 AM
K-5 ii vs K-5 iis comparison with higher sharpness in K-5 ii kataria0 Pentax K-5 62 12-22-2012 10:12 PM
K-01 Now or Wait for K-5 IIs or K-30? Biro Pentax K-01 10 11-21-2012 09:31 PM
Suggestion K-5 forum renamed to K-5, K-5 II, and K-5 IIs? Buschmaster Site Suggestions and Help 2 10-16-2012 02:17 PM
All times are GMT -7. The time now is 06:11 AM. | See also:, part of our network of photo forums!
