As it has been discussed here and elsewhere, the March 2008 issue of PopPhoto has a K20D review with AF speed data being identical to that of their K10D lab test back in Jan. 2007. It was suspected that they did not bother to test the K10D's AF performance in full detail but rather copied the K10D numbers and pasted over to the K20D review. There was also one apparent error during the process: The time for -1 EV (of the K10D) was plotted as 0 EV on K20D chart.
I posted a question to the editors on PopPhoto's forum with no response from them so far but I just saw that they responded to another thread here:
Uh-oh, shennanigans in the Pentax K20D review - Respond to Popular Photography & Imaging - PopPhoto
Online Technology Editor Jack said the following in a reply to the thread:
--- quote begins ---
FYI:
Executive Technology Editor Michael J. McNamara explains: Pentax openly admits that the K20D AF system is identical to the AF system on K10D with no claims for speed or sensitivity improvements. As noted in our several stories on the K20D, there are multiple design and performance elements that are identical between the two cameras since the K20D is actually a significant upgrade to the K10D but not a totally new camera design. Our preliminary lab findings supported the similarity in AF systems, and therefore we decided to incorporate the AF results from the K10D to minimize confusion. Had there been slight variations between the two camera models (as there would be), we would have received even more complaints after claiming both AF systems were the same. However, when the test data was incorporated into the K20D Test Results graphic in print and online, it is was accidentally transposed by one place. We have since updated the chart to correct this and believe the chart to be an accurate appraisal of how the K20D AF system performs compared to other DSLRs tested in the same manner.
--- quote ends ---
"we decided to incorporate the AF results from the K10D to minimize confusion"???
I have to say I am confused by this decision. Back in the days when they tested the K10D it was running firmware 1.00 presumably and it had no support for SDM lenses because SDM lenses were not out yet. Even if Pentax said the AF hardware is identical in the K20D, there have been revisions in firmware and most notably SDM support was added since 1.30. Since they tested the DA* 16-50 for the same March 2008 issue, at least we can expect them to re-test the AF speed using an SDM lens on the K20D and publish the full numbers. Granted, low light AF performance could still be bad and SDM may not improve speed much, but I don't think they would come out 100% identical to the K10D using body-driven AF.
I don't know about the rest of you but this is the kind of review philosophy and policy that I personally cannot agree with.
Best,
Peter
