03-05-2013, 02:42 AM   #196
GordonZA's Avatar
Rice high has posted links to some folk that have been out shooting with the 560mm, the FA*250-600 and another lens... Have a look at his blog...
Some very nice results of small birds in park.. With field comparisons...
03-05-2013, 02:43 AM   #197
Asahiflex's Avatar
QuoteOriginally posted by eurostar Quote
If you want it desperately, there is one on sale in Italy. 6000 euros like new. Pentaxiani • Leggi argomento - (VA+sp) Pentax F* 250-600 + tutti gli A* e FA*
That's my old F* 250-600 I sold to him! I hope it will end in the hands of a fellow Pentaxian
03-05-2013, 03:41 AM   #198
borno's Avatar
If you shoot large birds like cranes and herons OK, but if you shoot lilttle passerines you need to stop down at least to F/8 to have eyes and shoulders included in the dof. Sometimes shallow depth of field is worse on the output than high ISO. IMO.
I would still want sharp wide open with no CA (and a ring AF motor) and useable with a TC, or why spend that much. ?? Good service is important to me also, if you ever need it, and if you use your stuff a lot, you will eventually.
03-05-2013, 04:15 AM   #199
Right, at 10 meters a 600 at f4 has only 4 cms of depths of field; most of the time I stop my 600 to f8 to get 8 cms of depths of field to get managable depth of field
03-05-2013, 08:35 AM   #200
QuoteOriginally posted by Asahiflex Quote
Oh my, i might actually get it!!!!
I feel like i'm about to jump off a plane (with some parachute of some sort)!
03-05-2013, 09:47 AM - 1 Like   #201
borno's Avatar
QuoteOriginally posted by goubejp Quote
I like a little blur sometimes (300mm at f2.8)
03-05-2013, 09:53 AM   #202
falconeye's Avatar
Adam, thanks for doing this.
I am a bit confused about visible "print-like" texture in uniform black areas and no moiré showing up at Nyquist (it really should with the K-5IIs, it always does with my D800E having the same pixel pitch). So, I measured some MTF figures with hesitation. But here we go:
CA was about the same for both lenses and didn't really change with aperture. It was about 1.2px near the APS-C corners (70% from center) and 0.7px near the center (10% from center). Near the center, CA went down to 0.3px when stopping down.
Resolution in lp/mm (at 10% / 70% from center):
DA560 @F5.6: 22/19 line pairs per mm
DA560 @F8: 24/24 line pairs per mm
DA560 @F11: 26/26 line pairs per mm
FA520 @F5.6: 25/21 line pairs per mm
Note that the TIFF files are unsharpened output probably. The 10-90% edge rise width is pretty large (4,7px for the first figure of 22 lp/mm). But that's normal for unsharpened values. The corner sharpness was measured in the upper left und lower right corners with one of two orientations, and then averaged.
In order to calibrate the process and better judge the meaning of values, a similiar example of a K-5IIs with the DA70 at its sweet spot of F4.0 would be welcome.
From numbers alone, I would say that both, FA200-500 and DA560 are a bit on the weak side of things. 30 lp/mm curves should normally stay well above 50%. But it is easy to introduce blur in tele lens tests, quality of focus being one of them. The fact that center resolution improves when going from F8 to F11 (it really shouldn't for all but a lemon) is a hint in this direction. The total lack of Bayer moiré is another.
03-05-2013, 09:58 AM   #203
QuoteOriginally posted by borno Quote
Nice shot; wouldn't have been better with deeper depth of field? You have use it as a portraiture lens indeed
03-05-2013, 10:08 AM   #204
falconeye's Avatar
Not entirely on topic but worth a mention:
Nikon has updated the 80-400/4.5-5.6 and the new MTF figures look much more interesting -> Nikon | Imaging Products | AF-S NIKKOR 80-400mm f/4.5-5.6G ED VR
The 30 lp/mm MTF at the tele end stays above 65-85% (old version in the middle, reputed Canon 100-400/4.5-5.6L to the right):
Depending on what we find for the DA560, it may be another possible competitor, esp. if combined with an 1.4xTC which does still AF.
03-05-2013, 10:19 AM   #205
Ole
Ole's Avatar
Ii was actually I who was "volunteered" to do those DA560 tests and I have refrained form calculating any resolution numbers for the reasons you point out.
Obtaining 100% accurate focus is an impossibility by manual focusing a K-5 IIs so I resorted to relying on CDAF. So that's what you got and perhaps that's why F11 may look sharper than F8?
Eliminating any and all vibrations during the shot was very hard with this long bastard of a lens. If someone donates a much studier tripod than the one I've got (Manfrotto 458B) I'll reshoot The F*250-600 actually was more stable on the tripod (it also weighs more).
I was also baffled by the lack of moire, I can only chalk it down to lack of resolution due to either inaccurate focus of vibrations.
03-05-2013, 10:21 AM   #206
QuoteOriginally posted by Ole Quote
How long will you have the lenses?
03-05-2013, 10:26 AM   #207
traderdrew's Avatar
I have never seen a series of controlled tests for the Sigma 500mm F/4.5. Has anybody found some on the net? I have seen a report that it is sharpest around F/7.1 to F/8. I have this lens and I think highly of it. It seems to me that it can outperform the resolution of the K-5 when I nail some of my subjects.
03-05-2013, 10:27 AM   #208
froeschle's Avatar
F(A)* 250-600:
The Lens Design of SMC PENTAX F* 250-600
MTF, Position2
03-05-2013, 10:59 AM   #209
Ole
Ole's Avatar
QuoteOriginally posted by ElJamoquio Quote
The DA560: Through March 23.
The F*250-600: Forever, it is Adam's.
03-05-2013, 11:43 AM   #210
gazonk's Avatar
Isn't manual focus @ 10x in LV more reliable than CDAF?
560mm, lens, pentax news, pentax rumors
K-30 Manual Available now baka654 Pentax K-30 & K-50 28 01-12-2013 05:25 AM
News World Pentax Day Book Now Available! Adam Site Suggestions and Help 7 07-04-2012 07:39 AM
Nikon D800 images now available einstrigger Non-Pentax Cameras: Canon, Nikon, etc. 33 02-07-2012 12:52 AM
The new Topaz Lens Effects now available. Joyen Digital Processing, Software, and Printing 12 12-16-2011 07:37 PM
Samyang 35mm f1.4 now Available Damian Pentax SLR Lens Discussion 228 12-09-2011 03:04 AM
All times are GMT -7. The time now is 12:20 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
