Originally posted by aurele I found this : Samyang 50mm f/1.2 likely to come in 2014! | sonyalpharumors
Great, I have another prediction: my collection of 50mm lenses will hit 200 by 2020.
Originally posted by JinDesu Doesn't Canon also have a 50 1.2?
They do but it really isn't any better than the pentax 50mm f/1.2, in some cases the 50mm f/1.2L is actually worse than the pentax 50mm f/1.2. The canon 50L has a really big problem with purple fringing. Canon originally had a 50mm f/1.0 - but at the time so few of their cameras had AF that was accurate enough to use it.
