08-20-2014, 12:09 PM   #91
D1N0's Avatar
QuoteOriginally posted by ElJamoquio Quote
Honestly I'm not going to purchase a non-AF lens at or above 50mm.
Actually it is harder to focus with a wide angle mf than with a tele.
08-20-2014, 12:48 PM   #92
QuoteOriginally posted by D1N0 Quote
To get precise focus, yes.
A lot of the time, when I use a 200mm lens, I want a given 5 cm to be in focus.
A lot of the time, when I use a 20mm lens, I want a given 50,000 cm to be in focus.
08-20-2014, 03:44 PM   #93
Otis Memorial Pentaxian
schrödingers cat. Is it alive or is it dead. It's both!
...in or out of box or what box?! (Vivitar, Rokinon, Samyang, Bower, <put your name here>...)
---------- Post added 08-20-14 at 03:46 PM ----------
You would do well to not purchase an AF lens with an f/1.2 maximum aperture regardless of focal length. No current dSLR has an AF system capable of precise performance with a lens that fast.
08-21-2014, 04:12 PM   #94
Na Horuk's Avatar
Yep. And the stock focusing screen might also be inaccurate, so its best to buy a third party focusing screen specifically for fast primes
08-21-2014, 05:05 PM   #95
Already done. Plus I have live view.
08-21-2014, 05:46 PM   #96
Digitalis's Avatar
I have been using the stock screen and the SMCP-K 50mm f/1.2 without problem - though I will admit the O-ME3 viewfinder magnifier has been an indispensable accessory.
08-21-2014, 07:16 PM   #97
Got that too. I don't think it matters that much, but it helps a tiny bit.
08-22-2014, 12:41 AM   #98
thibs's Avatar
Ah, I don't think I'll need to change the default screen of all those manual focus Pentaxes I use
Oh I could even use it on my DSLR ! (yeah, I know perspective is a bit different for me).
08-22-2014, 04:24 AM   #99
Digitalis's Avatar
The other reason why I don't change my focusing screen is because third party ones nearly always mess with spot metering - which I use quite a bit.
08-22-2014, 04:47 AM   #100
thibs's Avatar
I admit, this is also a reason (for my DSLRs). I now always use a spotmeter with the 4x5 cameras so I have problems with anything but spot when doing serious work.
Of course I can use the spotmeter but well... that would a shame
08-22-2014, 05:26 AM   #101
Digitalis's Avatar
QuoteOriginally posted by thibs Quote
I use spotmeters for my 8X10 and 4X5 cameras too.
08-22-2014, 05:32 AM   #102
D1N0's Avatar
My focussing screen was front focussed. Very frustrating when shooting manually. Good enough for AF, pentax must have thought. Putting in a katzeye did not help except for front focussing more accurately. I had to replace the shim under (really above) the focussing screen for a thinner one. I find that the split prism is not very accurate. Too hard to see whether it is perfectly aligned. The micro prisms work better. More often then not I just focus around the entire inner circle on the matte... For a 1.2 lens i might get one of those canon screens with more accurate DOF rendering (I believe it is about F2 instead of F2.8).
08-22-2014, 06:33 AM   #103
thibs's Avatar
I wouldn't have thought you'd use anything else
---------- Post added 22-08-14 at 14:34 ----------
That's too bad
I guess modern DSLRs really aren't made for manual focus anymore at all.
08-22-2014, 07:43 AM   #104
D1N0's Avatar
I could use live view of course, but it is a bit laggy and I am just not used to it. Focus peaking is not very well implemented on the K-5 yet (zooming in, loosing your view on composition). Zoom out again and you are sure to have lost your focus unless working on a tripod. A well i'll just wait for the FF or get a Sony A7 for my manual glass.
08-22-2014, 07:59 AM   #105
carrrlangas's Avatar
Do you have experience with the Canon EE-S screen? does it affect spot metering, I got used to it quite a bit too.
50mm, af, art, f1.2, f1.4, focus, front, lens, light, otus, pentax news, pentax rumors, purchase, samyang, screen, sigma, steve, stop, zeiss
Trip to Africa in 2014 - what lens/camera? audiodoc Pentax SLR Lens Discussion 71 02-22-2013 09:41 PM
Portait lens - Pentax 50mm f1.2 (K version) or Samyang 85mm f1.4 Damon Pentax SLR Lens Discussion 17 01-21-2013 01:35 AM
Rikenon 50 f1.7 (P/K) vs Super Takumar 50 f1.4 (M42), which is better? fanofcc Pentax SLR Lens Discussion 15 09-15-2012 11:58 AM
Samyang 24mm f1.4 kevinschoenmakers Pentax News and Rumors 46 08-19-2011 08:23 AM
All times are GMT -7. The time now is 10:01 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
