02-22-2013, 08:13 AM   #181
monochrome's Avatar
IIUC, the real advantage of a FF camera over a top-end APSc camera is limited to the UWA boundary of an APSc for a given UWA lens, and the DoF boundary of an APSc for a given very fast lens.
If I rarely or never need to shoot outside the APSc boundaries, all other things being equal, I really don't need a FF camera to produce a similar or even an identical print.
02-22-2013, 08:17 AM   #182
audiobomber's Avatar
The only real FF attraction for me is one stop less noise. I don't expect I'll ever want anything but APS-C as my main camera, but a compact FF MILC would be interesting for casual use.
02-22-2013, 08:34 AM   #183
The Canon EF 16-35mm f/2.8L is bigger than the Tamron 16-50mm f/2.8 DX format lens - this is a fact.
A full-frame 16-35 f/2.8 on canon will make the same pictures as a 10mm-22mm F/1.9 or so on APS-C.
02-22-2013, 08:35 AM   #184
aleonx3's Avatar
QuoteOriginally posted by audiobomber Quote
Good discussion, thanks, I am not convince that FF will take over the APS-C. It may sound more significant to those who know very little about the pro-and-cons. Even if the FF becomes a main stream dslr or milc, I still want to keep the APS-C. My last on-stage shooting event convinced me more that I don't need a FF equivalent to get the job done better. I used my k-5 and DA* 50-135mm combo and I got more than satisfactory results - I don't want to lug around a 70-200 f2.8 or f4 with a FF body. Also, the argument about the ability to crop with FF sensor is not really an attractive point. However, WA and UWA shots will definitely be an advantage with the FF camera.
02-22-2013, 08:37 AM   #185
That's fine. If you don't care about the shallower depth of field or desire shallower depth of field then you're all set with FF.
02-22-2013, 08:41 AM   #186
QuoteOriginally posted by aleonx3 Quote
IIRC Canon's 24-105 F/4 (on FF) is sharper, slightly faster, slightly wider, slightly cheaper, and much longer than the 17-50 F/2.8.
I could be off on a couple of stats but, from a lens perspective, it was no contest in my mind. Camera bodies historically have been heavier on the FF side, but the penalty doesn't have to be much... the 6D/D600 are changing that.
I don't feel like looking up the Canon 70-200 f/4 and comparing it to the slower, slightly less wide, slightly longer pentax 50-135. The differences might be less than you think... often the FF lens is lighter.
02-22-2013, 09:31 AM   #187
QuoteOriginally posted by ElJamoquio Quote
The differences with regard to depth of field are primarily noticed on the wide end. There isn't really an APS-C equivalent of something like the FA 31 limited on full frame. That said, I don't really use shallow depth of field with wide angles. For most landscape photographers, the goal is to having things in focus, not blurred out.
02-22-2013, 09:39 AM   #188
Let's say I'm doing a 31 limited on full frame, say, a late sunset. I don't want any noise, so I'm shooting it wide open.
Hyperfocal is 60 something feet. Things are in 'acceptable focus' from 30 feet to infinity.
My friend is using a 21mm f/3.2 on APS-C. Hyperfocal is 24 feet. Everything is in 'acceptable focus' from 12 feet to infinity.
The APS-C/21mm has more things in focus but also has roughly 3 stops worse noise (or slower shutter duration), and only 65% of the sharpness (assuming both lenses are ideal, or at least equivalently flawed).
A lot of the time... maybe even MOST of the time, the landscapes I'm taking a pictures of are WAY past 50 feet away from me. The other times, I can go to F/5 on my FF, still have 1.5x better sharpness and lose nothing in DOF or SNR.
02-22-2013, 10:02 AM   #189
QuoteOriginally posted by WillWeaverRVA Quote
They have the K-3 and K-3s listed in April. Don't tell me they ran with the silly April Fools' joke too.
Of course, if it's true then I'll be telling Pentax to shut up and take my money.
Also, it makes me wonder if they'll make a K-300 to replace the K-r...
who are "they"
02-22-2013, 10:19 AM   #190
Clavius's Avatar
+1
A very compact MILC. Lots smaller then the 6D. Look how close in size the FF Canon 6D is to the APSC-C Pentax K5: Compare camera dimensions side by side
If it could also be more affordable, it would be a giant success.
02-22-2013, 10:22 AM   #191
Note to Pentax: people would want a MILC only if it's cheaper, preferably below production cost
02-22-2013, 10:49 AM   #192
Sounds like you need a tripod.
02-22-2013, 10:52 AM   #193
Clavius's Avatar
From what do you draw that conclusion? I think anyone would understand that a lower tier MILC is to be priced accordingly, and a pro level MILC accordingly.
02-22-2013, 11:18 AM   #194
As Dan says, you need a tripod. I shoot at iso 80 when shooting landscapes as much as possible, primarily due to the significantly better dynamic range you get there. In addition, I am usually stopped down at f8 to f11 and prefer to have something relatively close in foreground that I can focus on, while keeping background sharp. An FA 31 at f1.8 on full frame is just not going to cut it for for most landscape photography.
02-22-2013, 12:12 PM   #195
acoufap's Avatar
QuoteOriginally posted by Clavius Quote
+1
Recently I shot nearly 200 Photos with the Canon 6D / L-Glass f4/24-105 at a sports event in a sports hall. The 6D worked great and for me the ergonomics were ok. Size and weight are not that different compared with the K5. To me the image quality of the 6D seems to be similar the K5's (I always develop jpegs from raw). The reason I would like to have a FF camera:
- big bright view finder (pentaprism based - I shoot a lot of macro photos)
- image quality above ISO 3200
- wide and ultra wide photography
So I hope Pentax will offer a FF camera within two or three years. But before I would like to see a great sharp fast FF WR alround zoom lens - something like f2.8/16-85 - with high resolution from the center to the edges over the hole zoom range, no PF, no distorsion and with high build quality at a not too high price tag. This would fit for both: my K5 and a Pentax FF camera in the future
acoufap
pentax cameras, pentax news, pentax rumors
Minikina 2013 vsl 01/02.06.2013 in Wiesbaden veraikon General Talk 9 05-27-2013 10:37 AM
Weekly Challenge POTW #251 27 Jan 2013 through 10 Feb 2013 Dr Orloff Weekly Photo Challenges 54 02-10-2013 11:59 AM
Weekly Challenge POTW #250 20 Jan 2013 through 3 Feb 2013 Douge Weekly Photo Challenges 43 02-03-2013 09:45 PM
PENTAX Introduces New K-5 II & K-5 IIs DSLR Cameras Versatile cameras feature newly d Adam Homepage & Official Pentax News 18 09-13-2012 07:14 AM
NEW Pentax Lens Roadmap 2012/2013 oddesy Pentax SLR Lens Discussion 331 04-07-2012 02:42 PM
All times are GMT -7. The time now is 10:34 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
