Originally posted by aegisphan So what you are saying is that if i get my K20D, and add another one to "save for later", i would get a refund down the road? It sounds too good to be true.
Sorry, should have more clearly stated the 30 day value - thanks ankit.
Having it as a "Saved for later" item just makes it easy for you to notice when the price changes, because when you click on the Cart link, they will list any items that have changed in price. That way, you don't have manually go checking, it's just an automatic notification. You get the same notification if it is in the active part of your cart, but with it saved for later, you're less likely to accidentally buy another one.
When you see that the price has changed, you then request the refund by clicking on the Help link (upper right), then the Customer Service button (right side of page). From there, a couple of options, but the one I used was the "e-mail" tab. Select the order, set issue to Refund, and add a note indicating the price dropped and you would like a refund. Don't know if the note helps or not, but...
