Closed Thread
03-14-2013, 09:33 AM   #106
QuoteOriginally posted by audiobomber Quote
The sensor in the K-3 rumour is the same one used in the A77 and NEX7. DR and noise will be pretty much the same as the 16mp bodies
If the DR and the noise will be "pretty much the same" as the K-5, why would the K-3 be any more compelling an upgrade than the K-5ii? PopPhoto test the NEX 7, and found it yielded 2740 lines per picture height; the K-5 scored 2590 lines per picture height. That's a 5.7% difference. It's unlikely that at large print sizes anyone could tell the difference between images shot with the K-5 and a 24 MP K-3. But processing times might well be noticed, to the detriment of the K-3. 50% bigger file sizes for 5% increase in resolution is a downgrade, not an upgrade.
Now if Pentax vastly improved the tracking AF, that would certainly qualify as a compelling upgrade, but in that case, the K-3 would be more of a professional sports camera, and those cameras have lower MP counts, not higher (think Nikon D4 and Canon 1dx).
Perhaps Sony's new 20 MP would make more sense. That sensor is rumored to have improved dynamic range and perhaps as much as a one stop improvement in high ISO performance. If we're going to have to put up with larger file sizes, at least we ought get something more tangible and useful than a mere 5% increase in real resolution.
03-14-2013, 10:06 AM   #107
Wired's Avatar
the D600 process files very quickly. I think if Pentax were to upgrade the processing engine to at least that of the D600's caliber, if not better we shouldn' thave a problem.
03-14-2013, 10:29 AM   #108
So much speculation.... Sure i might get the K3. Depending on the lens / aperture / flash used, there should be considerably more resolution at 24 as opposed to 16 mpx. Also, i think there is room for a model ABOVE the K5(iis), with pro AF, dual cards... Though i'm not complaining any more, firmware 1.14 was awesome on the K5 (regarding AF).
That said, I think the peaty smokey whiskey conversation is much more interesting!
Cheers (with a glass Ardbeg)!
03-14-2013, 11:56 AM   #109
Wired's Avatar
QuoteOriginally posted by Clavius Quote
I was trying to ignore all these posts that are making me so thirsty, but I'm failing at that. Laphroaig is my favorite brand. I used to work for Allied Distillers in Holland; I blame them for teaching me how to drink the stuff. It goes so well together with a nice dark Brazillian cigar..
I gave up smoking this past winter... but people keep buying me cigars. Something had to give because the wallet was getting empty way to fast... cigars were the one to go because they are not a good return on the money... but I usually like the Cubans myself. I've had some Brazillians, but I don't recall what they were...they were smooth though. I usually enjoy the Romeo Julietas
03-14-2013, 12:10 PM   #110
audiobomber's Avatar
I enjoy a good cigar. I smoke about four a year, usually Cuban. Never with single malt though. Malts are too good to corrupt with cigar flavour. If I have whiskey with a cigar, it will be bourbon.
03-14-2013, 12:11 PM   #111
mikeSF's Avatar
i remember this same thread last April...1st.
03-14-2013, 12:16 PM   #112
monochrome's Avatar
QuoteOriginally posted by mikeSF Quote
Beware tomorrow
03-14-2013, 12:26 PM   #113
normhead's Avatar
QuoteOriginally posted by JinDesu Quote
Replacing the k-30? Or taking place below the k-30 as the cheapest/lowest Pentax DSLR product?
Take take "best APS-C", it's gonna need better AF than the D7100, and probably better than the upcoming Canon 7D2.
I always go back to which one is capable of taking the best images. How much trouble I have to go through to get it is not an issue. It continues to blow me away that people talk about AF as critical to a camera, , when many of the best images, are taken with no AF. So, you and I are just going to have to differ on this.
03-14-2013, 12:42 PM   #114
jatrax's Avatar
Different photographers, different needs but I'm with Norm, AF on the k-5 is more than good enough for me. Really don't understand how it could be improved for what I shoot.
I guess if you are tracking birds in flight or airplanes or something but I've never used AF.C just don't shoot that kind of stuff.
03-14-2013, 12:48 PM   #115
JinDesu's Avatar
If they want to lay claim to "best", then they have to have good AF, unless they are so much more better at everything else.It's not a question about whether you or I find the AF sufficient. It's whether the product is better than others to claim the title "best".
The k-5 claimed king of affordable APS-C for great form factor, best low-light performance, best DR, proven weather-sealing, fast frame-rate, silent shutter, etc. It was only lacking in AF in comparison to the 7D and the D7000 - but it was so good at everything else, it took the crown. The new generation of APS-Cs are coming out (or in the D7100's case, has come out). If the k-3 doesn't exceed these gens in the performance factors above, a substandard AF system will mean it cannot take the title "best".
03-14-2013, 12:51 PM   #116
My DA*300 won't focus in low light or low contrast on my K5. An improvement in low light and tracking accuracy in afc mode would be worth the upgrade for me. As well as faster recovery from multiple shots.
03-14-2013, 01:13 PM   #117
normhead's Avatar
But that's exactly the case, in DxO tests the K-5 is marked down for it's AF speed, but get a higher mark based on IQ, DR and noise reduction.
03-14-2013, 01:17 PM   #118
normhead's Avatar
QuoteOriginally posted by northcoastgreg Quote
POP photo also only lists the D800 at ISO 50, it served up 3510 lines per picture height. The simple fact is, finer detail increases the price exponentially.
The D600’s imaging proved well above economy class, with an Excellent rating in overall image quality in our tests from ISO 50 through ISO 3200. Its resolution was particularly impressive: 2930 lines per picture height at its lowest sensitivity of ISO 50.
Combine the 2740 for a NEX 7 and combine it with 8% for going AA filterless and you've got 2959, better than a D600.
03-14-2013, 01:49 PM   #119
Mistral75's Avatar
Count me among the Bruichladdich fanboys, 3D Moine Mhor ("Big Peat) being my favorite and Port Charlotte An Turas Mor a close second.
I understand from this topic that the latter won't be produced anymore: so sad... Is it because of Rémy Cointreau taking over the distillery?
03-14-2013, 01:57 PM   #120
JinDesu's Avatar
That's the case for the k-5. Not the k-3. Not yet - and it's a much stronger field now, with the D7100 and the potential 7D2.
Closed Thread
645d, camera, ii, k-3, pentax k-3, pentax news, pentax rumors, source
For Sale - Sold: For Sale in Australia Tamron 18-250, Takumar 135 / 3.5 and 2.5,Pentax SMC K 200 Westoz Sold Items 15 06-07-2012 04:24 AM
Georgia Judge Orders President Obama To Appear In Court To Defend Citizenship jogiba General Talk 5 01-25-2012 12:56 PM
Error NSFW does not appear in Tapatalk selar Site Suggestions and Help 3 04-14-2011 01:34 PM
For Sale - Sold: m42 Tele-Takumar 300mm F6.3 and GENUINE Pentax m42-to-K adapter (US/CAN) LowVoltage Sold Items 5 03-22-2011 05:55 PM
For Sale - Sold: Pentax *ist DS2 Body / Katz-Eye w/Split Micro Prism and rule of 1/3s / NiMHD B MikeDubU Sold Items 6 02-11-2009 11:31 AM
All times are GMT -7. The time now is 12:19 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
