Originally posted by Tom M I think the obvious answer is that the 645 is a fine camera and design as well as format HOWEVER, the 67 (6x7) covers the 645 (6x4.5) format while providing more area of coverage for those who want it. Those who don't can simply crop to 6x4.5... So, if you're going to produce a MF digital camera it makes no sense to develop the smaller of your two formats as all things being equal, you'll pay slightly more for the larger sensor but gain far more versatility.. My money is on a 67D to replace the 67II...
I don't want to rain on anyone's parade, but this just isn't going to happen. At present, the largest "digital 645" chips around, those from PhaseOne and Hasselblad, come in around 37mmx49mm. That's short of the actual 645 negative, which is 41.5mmx56mm. The traditional 56mmx56mm square format has been reduced significantly to around 37mmx37mm for backs with square sensors. There's a limit to the size you can make a chip, and full 645 (41.5x56) would be achievement enough. A full 6x7 chip (at 56mmx69.5mm) is just impossible at the moment.
If/when Pentax makes a digital MF camera, it will have a chip smaller than 645, and thus be compatible with 645 lenses (as well as 67 lenses, as all 645 bodies have been). The last prototype was using a chip that measured 33x44mm. That's a crop factor of 1.27, in case anyone's counting, and not nearly as good as the 1.14 that others are getting at present.
Will
