Originally posted by Digitalis There will be a penalty - field curvature and coma.
According to lenstip the DA 21 has worse coma than the 18-35 wide open, not that I have ever noticed a negative impact of this since I don't make photos of diodes.
Similarly, I've yet to encounter a situation where field curvature would cause an issue on any lens, because I don't make photos of brick walls.
Nothing is perfect.
I've just uploaded a
new photo (at full resolution for Flickr members), typical wide angle subject taken at 18mm and f/1.8 for testing purposes, and it appears I was far enough back that infinity is in decent focus too.
At a regular viewing size you will see a bit of vignetting and distortion, which a lens profile would sort out with one click. Getting down to pixel peeper resolution it can be seen that the extreme left and right edges of the frame are soft - and if you look in the shadows you will see chroma noise because the Canon sensor/RAW file is awful for shadow recovery.
All that aside, and backing out to normal viewing size again, perhaps one could appreciate how surprisingly good this looks for a photo taken with a lens wide open (zoom or prime) at f/1.8.
