07-07-2014, 08:16 PM   #1036
panoguy's Avatar
In a nutshell: you have FF/BF issues? too bad, sigma will just tell you to get the dock (which is another $89 for Australians).
Are you reporting from experience or are you just speculating?
I'm fairly sure that Sigma will look at a lens and even calibrate it for you if you ask them to, despite the existence of the dock. I have to admit that I don't really know (I only have excellent experiences with Sigma regarding lenses that precede the dock) but I'm not making a statement without expressing that I'm making an assumption.
The treatment you get from Sigma's distributors can be all over the map. Here in Canada, their distributor will calibrate your Sigma lens to any single camera you choose, for free, as many times as you switch camera bodies. It takes a week or so for them to get around to it, and yes, it's only for a certain focal length with zooms. I had both my old 150-500 and 50-500 calibrated this way to see which was better at 500, and while they ended up equal, the 50-500 was nowhere close to begin with.
My SA-mount 18-35 required a small AF adjust in the SD1M (yes, Digitalis, I'm one of those folks), and while it came with the USB dock (long story), I've never used it. Always quite happy with the performance of this lens on my Foveon body, and that makes it the only zoom I can say that about. Other than that, I stick to their macro lenses (the 180mm is a beast!).
QuoteOriginally posted by DSims Quote
Before I get all kinds of grief for putting the DA20-40 down, it does have virtues - like small size and excellent build quality.
HERETIC! Light the torches! Sharpen the pitchforks! Don't you know that's a Pentax Limited you're talking about!??
07-08-2014, 01:12 AM   #1037
Class A's Avatar
QuoteOriginally posted by panoguy Quote
Mmmh, that's one lens I'd like to get my fingers on...
I have the Sigma 70/2.8 EX which I cannot fault optically, but more stand-off distance would sometimes be useful.
I wouldn't mind a Pentax FA* 200/4 macro either, but saying it's expensive would be an understatement.
07-08-2014, 01:37 AM   #1038
Digitalis's Avatar
this is OT but I have the Sigma 180mm f/3.5 EX MACRO and the FA*200mm f/4 ED MACRO. Considering your experience with the Sigma 70mm f/2.8 EX the Sigma 180mm f/3.5 EX MACRO would leave you disappointed (optically, it isn't anything to write home about. However the FA*200mm f/4 ED Macro is simply stunning, especially on the K5IIs).
07-08-2014, 03:06 AM   #1039
Class A's Avatar
Lucky you!
Considering your experience with the Sigma 70mm f/2.8 EX the Sigma 180mm f/3.5 EX MACRO would leave you disappointed (optically, it isn't anything to write home about...
Six 10s and three 9s awarded by PF reviewers speak a different language.
If it weren't for one -- let's call him "outlier" -- who scored a "1", the score average would be an impressive 9.67.
IIRC, you mentioned (long distance focus) issues with your copy, so perhaps it isn't quite OK. Not sure why you are keeping both Sigma 180mm and Pentax 200mm macros. Even if you won't get much for the former (IIRC, it had cosmetic issues as well), it would still be more than nothing which is what you have now if you always prefer the 200mm anyhow.
07-08-2014, 04:03 AM   #1040
Digitalis's Avatar
You can't remove the tripod mount on the FA*200mm f/4 ED MACRO which makes the lens profoundly uncomfortable to carry in my everyday Flipside 300 bag. Also the Sigma 180mm f/3.5 is smaller and somewhat lighter than the FA*200mm f/4 ED MACRO.
I have tried several other copies of this lens at similar focusing distances on different bodies - all of them had exactly the same issue.
All those lenses produced results like this:
Pentax K5IIs - Sigma 180mm f/3.5 EX MACRO @ f/3.5 distant focus
I know you probably can't see it in that reduced size image but nothing is critically sharp in that image, and that doesn't change at all when you stop the lens down.
Having said that, the lens is excellent at close focusing distances:
Pentax K5IIs - Sigma 180mm f/3.5 APO EX @f/5.6 ISO 3200 1/640th
Personally I prefer to use my Sigma 100-300mm f/4 APO EX DG for long distance scenery (an embarrassing situation where a telephoto zoom does better than a macro prime) I use the Sigma 180mm f/3.5 EX for closer up work which the Sigma 100-300mm f/4 APO EX DG doesn't do well at all. At focus distances below 2.5m the image quality from the sigma 100-300mm f/4 APO EX takes a nosedive, no matter the focal length or aperture used.
07-08-2014, 06:14 AM   #1041
Edgar_in_Indy's Avatar
Are there any lenses you don't own?
07-08-2014, 06:35 AM   #1042
dadipentak's Avatar
QuoteOriginally posted by Edgar_in_Indy Quote
I think the answer is 'yes' (but those are the ones he's owned, tested and found wanting. ;~)
07-08-2014, 07:07 AM   #1043
Emperor and Senpai
VoiceOfReason's Avatar
Mine is out for delivery via UPS!
07-08-2014, 07:31 AM   #1044
I got mine last night; I'll be taking it for a quick spin at lunch time.
07-08-2014, 09:05 AM - 1 Like   #1045
QuoteOriginally posted by DennisH Quote
We'll keep our fingers crossed that there will be some cats handy!
07-08-2014, 09:25 AM   #1046
Birds and flowers for sure.
07-08-2014, 04:36 PM   #1047
Emperor and Senpai
I got mine and did some messing with it. Here's a link to some .dng files for you to play with to see how it does. I think I need a slight adjustment on it, and for some reason it meters really weird. Anyway, enjoy! https://www.dropbox.com/s/ahk5dhnsk77xnzz/samples.rar
07-08-2014, 06:25 PM   #1048
distudio's Avatar
I got mine yesterday, I've done some test shots and it looks good, it will be put to a real world test this week though as I have three shows to shoot. I will do some comparisons with my FA31LTD at some time but I don't expect the 31LTD will perform particularly well at 18mm, that's why I own both (for now, I've given up on FF from Pentax so the 31LTD may end up on the chopping block).
07-08-2014, 10:52 PM   #1049
QuoteOriginally posted by VoiceOfReason Quote
Like in a nominally dark room completely overexposes?
07-09-2014, 05:29 AM   #1050
Emperor and Senpai
QuoteOriginally posted by Rich M Quote
Outside it seems to underexpose while wide open judging by the light meter if the sky is in the shot, other than that yeah, where it is darker I get overexposure. I can compensate for it pretty easily though. I simply have to learn the lens.
18-35mm, angles, aperture, cameras, canikon, canon, dc, f/2.8, f1.8, fisheye, hsm, iso, k-3, landscape, length, lens, lenses, motor, mounts, nikon, pentax, pentax news, pentax rumors, review, sigma, sigma 18-35mm f1.8, sr, uk, zeiss
Sigma 35mm F1.4 for Pentax: ETA 4/30 Adam Pentax News and Rumors 181 02-16-2014 06:44 PM
Sigma 18-35mm f/1.8 detail. rlatjsrud Photographic Industry and Professionals 42 10-06-2013 01:41 PM
New Sigma 18-35 F1.8 APS-C yygomez Pentax SLR Lens Discussion 10 04-19-2013 04:11 PM
Pentax 35mm F2.4 AL DA L Lens vs Sigma 28mm f1.8 Aspherical orchid Pentax SLR Lens Discussion 8 04-22-2011 12:44 AM
All times are GMT -7. The time now is 11:55 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
