Originally posted by konraDarnok . why not ask someone who owns a Hasseblad H3DII?
I don't know anyone with a 40,000 dollar camera. Do the pictures really look 39,000 dollars better?
i have seen shots taken from a P20+ Phase one back, it is 16mp and measures 36x40mm and made the EOS 1 DS MkII look like a point and shoot even though they are/were the same resolution.
Surely there are some files to download of a side by side comparison of the exact same subject to demonstrate what you're saying. I'd like to see this.
I believe that APS-C has reached film quality, but if a simple size adjustment can get you campatability with existing lenses
My 'full frame' lenses are fully compatible. I don't understand what you're saying. You can get a bit wider field of view with a 35mm sized sensor, but so can you with a different lens. It's just a size -- there's nothing more 'correct' about it.
Besides, I'd kinda like to see a super fast lens, that *should* be possible with a smaller sensor.
People talk (and lust) after bigger than APS-C format because of one good reason: bigger photosites give better results than small ones.
I buy this when you're talking about the *tiny* sensors found in point and shoot cameras. Is it really that different when talking about the difference between APS-C and 35mm sized sensors?
Furthermore this assumes that sensor's big difference is size. It's not. There are numerous ways that sensors are different. . from how they render color, to the size of the photosites, to the shape of the photosites, to the post processing that the raw data gets in the camera, and there are probably others.
That's why I think the comparison between the D300 and 5D is a bit misleading. There are a lot more differences between those two cameras than the sensor size -- I see no reason to assume the sensor size is the deciding factor.
And this completely ignores what photo paper itself is capable of resolving once you take these pictures from the computer to the real world.
Digital is in its infancy. . and the technologies of the sensors are changing all the time. This focus on size is bizarre. It shows a mindset that only thinks about film.. . where size did matter.
Personally I think people repeat a lot of common wisdom.
I like to take pictures. So I visit photo sites like this one read up on lenses and what not. . get tips.
I also listen to audio a lot. So I visit sites about audio equipment too.
Both of these communities are similar in lauding ridiculously expensive equipment, conflating analog and digital technologies, and repeating things that on their face may be true, but not entirely important as the sole measure of what the piece of equipment is supposed to do.
I'm not disagreeing with the majority opinion the subject in here, so much as questioning the wisdom.
the wisdom lies in that, as of right now, larger sensors are the ONLY way we can reduce noise, as MP saturation goes up. if you look at an ISO 64 shot from a medium format digital, compared to that of a FF DSLR, and down to that of a APS-H, APS-C, or any other smaller sensor, cropping so that pixel density stays the same, you will NOT see a difference. BUT, if you have a 20mp APS-C vs a 20mp FF vs a 20mp medium format, the fact that the pixel density drops, helps decrease noise, and therefore produces a smoother, crisper image. it's the same reason why the smaller mp numbered *ist and k100d's seemed to have less noise at high ISO, the smaller pixel density helps reduce noice, which increases sharpness and definition..
Quote: Many of the reasons Medium format existed are not as true anymore.
DSLRs have long since surpassed 35mm film in most categories. . with the exception of dynamic range. . and even that is getting better with each new generation.
I may be completely wrong, but I don't see the endless debates on sensor size as being the future.
until we find out some better way to reduce noise, without increasing size, then yes, increasing size is going to be the future.
