Originally posted by starbase218
IIRC, a recall was made.
Yes they did:
K-5 Sensor Stains | Ricoh Imaging Support
I suppose the difference was a clearly noticeable problem that affected many (most?) of a particular batch or production run. As opposed to a problem that manifests itself only in a small percentage and at seemingly random lengths of use, without a clearly defined batch or lot number. We don't really know what percentage of SDM failures there have been, IIRC Camera Lens Rentals reported the SDM issues were statistically no different than other brands' problems.
I'm not sure the SDM issue rises to the 'recall' level. As I said before IMHO they should have issued a service bulletin and extended the warranty without making a fuss. But what 'should' happen and what does happen are often two different things with lots of variables. This issue also spanned Pentax>Hoya>Ricoh so perhaps the transition was part of the problem. Hoya certainly would not have wanted to state they had a problem that might require a lot of warranty repair cost if they were trying to shop Pentax around. Now it is Ricoh's problem and the only public comment we have from any of the corporate entities is a statement from Ricoh that it was a problem and it is now fixed.
In my experience with Ricoh, (with copiers) they don't have a lot of tolerance for manufacturing problems. If something is not working right, it gets fixed, period. And they have gone to almost incredible lengths to make something as minor (IMHO) as a tiny squeak in the paper feed of our copier go away.
Just my experience over the years but Pentax has always made innovative products but their quality control in some cases was a little lax. Ricoh in my experience may not be cutting edge but the attention to detail, fit and finish, and quality control are exceptional. When they build something they expect it to work. I think the fusion of Pentax thinking with Ricoh manufacturing is going to produce great things. It may take longer than we want but I think the combination will be very good in the long run.
