Originally posted by thibs
You got it completely wrong, would you re read your post on which I commented before writing nonsense ?
You argued that FA Limited are not tiny. They ARE for what they are. Compare with size/weight from the other brands.
That was my point. FA Limited ARE compact.
If comparing with closest equivalent lens of competition, it's not a major difference in size between Pentax FA31, FA43 and FA77 compared to Nikon 35/2, 50/1.8 and 85/1.8. Pentax FA Ltd has some unique qualities, but size is probably one of the least unique features, at least if compared to Nikon screw drive lenses.
Pentax FA 31/1.8 - 69 x 65 mm, 345 g
Nikon AF 35/2 - 65 x 45 mm, 205 g
Pentax FA 43/1.9 - 64 x 27 mm, 155 g
Nikon AF 50/1.8 - 63 x 38 mm, 155 g
Pentax FA 77/1.8 - 64 x 48 mm, 270 g
Nikon AF 85/1.8 - 72 x 59 mm, 380 g
Pentax FA 31 vs Nikon 35: Pentax has size disadvantage as using shorter focal length.
Pentax FA 77 vs Nikon 85: Pentax has size advantage as using shorter focal length.
The latest version of Nikon lenses with built in AF motors make lenses increase in size (but they still have the old version with screw drive is still available). Users that got FA Ltd on Pentax, might go nfor lenses with AF motor or f/1.4 lenses if jumping to Nikon, so in that case the lenses get much larger.
