09-13-2013, 03:15 PM - 1 Like   #46
QuoteOriginally posted by Old Man Quote
I did not see anything for the K10D. What is a K10D lover supposed to do? Just put them on a shelf and admire them?
Nothing for the K-x or K200D either.
But both cameras still work fine, just like they did before, and will in future.
The new flashes will no doubt still work on older Pentaxes, and lens data/ optical correction formulas for the new HD lenses is no big deal to me.
09-13-2013, 03:43 PM   #47
Mistral75's Avatar
It's indeed a pity not to benefit from an optimized contrast autofocus when using HD Pentax-DA Limited series lenses with one's K10D in video or live view mode .
09-13-2013, 04:36 PM   #48
mee
I just discovered that I had v1.03 on my K-30 so I decided to play it safe and just attempt 1.05 for the K-30
it appears the K-30 doesn't even acknowledge the K-50 firmware on my sd card.. there is no option at all to install it.
I, however, have discovered if you rename the K-50 firmware to 'fwdc215b.bin' (which is the v1.05 K-30 firmware filename), then the K-30 will give you the option to install the K-50 firmware -- says 'Ver.1.05 --> 1.01' on my screen.
Too concerned it will brick the camera to try it.. but it would be interesting to see if it unlocks the extra ISO setting... and still keeps the camera functioning.. haha
Would further confirm it is the same camera as the K-30 aside from a different shell and firmware... unless it, of course, bricks your camera..
09-13-2013, 05:17 PM   #49
QuoteOriginally posted by mee Quote
Whoever tries this is a braver man than I. I wonder if you would receive the same option if you renamed a update file for say the k-500 you would receive the same option.
09-13-2013, 06:55 PM   #50
mee
Good question.... would make that a cheap way to get AF point markers in the viewfinder.. provided it doesn't brick the camera.
I was very tempted to try installing the K-50 firmware on my K-30 but held off when I looked up previous bricked endeavors from fellow Pentaxians years ago.. apparently CRIS charges 200+ USD to repair a bricked camera???
I'm guessing the firmware is likely to install though since the cameras are so close to the same, hence my desire to try... but it is a risk..
09-14-2013, 03:42 AM   #51
Aristophanes's Avatar
The K-500 is missing the AF overlay hardware. It's not a software issue.
09-14-2013, 04:50 AM   #52
thibs's Avatar
Support for lenses is only for optimized contrast AF. Not the optical corrections, these are embedded in lens.
09-14-2013, 09:42 AM   #53
mee
QuoteOriginally posted by Aristophanes Quote
okay.
09-14-2013, 11:39 AM   #54
slip's Avatar
for some reason the link says it is for 1.05 but the file is 1.04 for k5iis
anyone else get this as well?
after the update it still says 1.04
did it get pulled?
thanks
randy
09-14-2013, 12:36 PM   #55
Mistral75's Avatar
QuoteOriginally posted by slip Quote
did it get pulled?
thanks
randy
See on page 2:
09-15-2013, 07:18 AM   #56
my K5 LCD screen blackout about 3/4 of the update, i waited a while but the screen still show nothing. I then turn off and on the camera and it seems like the camera is dead (no sounds and LCD screen display upon turning on the camera), except the battery life on the top control panel. I pressed the shutter button, it autofocus and take a shot without showing anything on the screen (neither saving any pictures in the sd card). I removed the batteries, sd card and lens from the camera for 20 min and put it back on, still it doesn't work. What should I do now?
09-15-2013, 03:29 PM   #57
mee
QuoteOriginally posted by zack87 Quote
Does it seem that the controls on the back still work (to maneuver through the menus on the LCD)? IF so I'd find a listing of steps on how to get to the flashing setup and enable that again... that is try to flash it again.. after you ensure you have a fresh battery..
09-15-2013, 05:30 PM   #58
nope, nothing work except the shutter release button. I called the service centre and will send it to repair later. Hopefully it won't cost much and take to long to get it back...
09-15-2013, 05:58 PM   #59
bxf
bxf's Avatar
It may be worth trying the process again: SD card with the appropriate firmware, then turn the camera power on while pressing the MENU button. If you're lucky, the update process will start.
09-16-2013, 01:26 AM   #60
QuoteOriginally posted by bxf Quote
tried it and no luck for me. I sent it to the service centre and it will take 4-6 weeks until I get it back. Thanks for the help though.
firmware, k-5, models, pentax, pentax news, pentax rumors
New Pentax K-5, K-5 II & K-5 IIs Adobe Camera Profiles PentaxGuyUK Post-Processing Articles 7 12-04-2014 05:02 AM
New Firmware For K-01, K-30, K-5, K-5 II, K-5 IIs, K-r Adam Pentax News and Rumors 63 02-18-2013 02:04 PM
K-5 II and K-5 IIs Firmware 1.01 Available Adam Pentax K-5 & K-5 II 10 01-18-2013 08:35 AM
Suggestion K-5 forum renamed to K-5, K-5 II, and K-5 IIs? Buschmaster Site Suggestions and Help 2 10-16-2012 02:17 PM
New firmware: v1.13 for K-5/645D, v.1.12 for K-7/K-r, v1.03 for K-x Adam Pentax News and Rumors 71 05-15-2012 01:42 PM
All times are GMT -7. The time now is 10:20 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
